Hall Effect Sensor Normally Closed to Normally Open
Madaxe
Aug 21, 2023
14
I have these little Hall Effect Sensors VCC is +5volts and Output is +5Volts Normally Closed State until a Magnet is passed by the sensor and then the Output Drops to 0V / Open Circuit.
My CNC machine requires a switch that is Normally Open, until the limit switch closes and send 5v tot he controller.
I need some help creating a simple circuit that will invert this state.
I believe i need an Inverting Amplifier circuit, if this is correct I have no idea how i would build one or what the resistor values would be.
Can anybody help
Marc
14,317
Can somebody show me a bread board diagram of the best solution?
Define "best"?
Here's a simple solution:
When in = 5 V, out = 0 V.
When in = 0 V, out = 5 V
But, there's a potential catch: When curent is drawn from "out" while out = 5 V, this current will pass through resistor R1 and thus a voltage will drop across R1. Consequently the voltage on "out" will drop below 5 V.
Since we don't know the current your CNC machine draws from out, we can't account for this effect.
Another option, as pointed out by @danadak , is the use of an active inverter, e.g. a NLV18HC1G04-D:
Make and model? There may be other options.
danadak
Feb 19, 2021
1,104
The SN74AHC1G14 should suffice, just the part no other passives needed other that a bypass cap
across its VCC and ground pins, say a 4.7 uF 10V tantalum :
Note the transistor circuit, with 2 Rs and a cap, more parts but easier to build a
perf board prototype than the above, your call poster.
Regards, Dana.
Madaxe
Aug 21, 2023
14
That's awsome, best i would define as something a Mechanical Engineer, like me could follow as long as i can drop it on a bread board plug some little wirethings in and it works i will be happy, so i think you guys are awsome and its a black magic to me.
Madaxe
Aug 21, 2023
14
I'm in the US. I found this guy does it still need a bypass cap to smooth the output signal? Thanks Marc
  • MC74HC1G04-D.PDF
danadak
Feb 19, 2021
1,104
Bypass cap is used to insure clean logic level out and to remove noise at supply pin
that would glitch the output.
Regards, Dana.
Madaxe
Aug 21, 2023
14
I'm using EasyEDA this is what I have so far based on your recommendations. With 8 x RJ9 connections to my Hall Affect Sensors and the ability to tie two outputs together.
I still have to add a power supply i have 24volts, so any ideas there would be great.
I'm also looking for any recommendations
Marc
Madaxe
Aug 21, 2023
14
I found this circuit, i implemented into my board. I think its correct but I'm really not sure can anybody review it for me?
Marc
Madaxe
Aug 21, 2023
14
i changed to surface mounted components for the buck converter, is there a free software i can test the circuit in?
can anybody review this for me?
thanks
Marc
You could save a lot of bother if you tossed your existing hall sensors and used maybe a n/c reed switch.
There is also the option of using a standard hall effect module such as a KY-003 which has open collector output and pulls low under a magnet.
Seems to me you are over thinking the application.
Madaxe
Aug 21, 2023
14
I have already built my own sensors and now i need to build the controller board, im already into it so what's a little more plus im learning from great people like you.
Plus this might help somebody else.
I added some 5volt take offs for other things, and thickened the tracks where i thought i would have to based on the current / voltages.
I'm still looking for some software to test before i order any thoughts?
Marc
There is a lot to be said for the kiss phrase.
Keep It Simple Stupid.( latter not my words mind you but the rest always applies).
Madaxe
Aug 21, 2023
14
Thanks for the great positive, my board works great, and does exactly what I wanted. I want to add some addition features and capacity so I'm working on the next generation.
I think this is what i need, can anybody help
Madaxe
No idea what your mosfet diagram is supposed to represent in the real world.
As drawn it's simply a dead short.
mrbuseco
Mar 11, 2025
What you want is not a Hall Effect (HE) sensor, but a Proximity Switch. Just type Proximity Switch into your favorite online crap store. Or, you could devise a system whereby your CNC gantry pushes a magnet away from the HE sensor.
Fyi, the nature of the Hall Effect is that a magnetic field disturbs the flow of electrons moving in a straight conductor, keywords MOVING and STRAIGHT. Thus, I am not sure how but they can stop current, with said current being restored by taking away the magnetic field. But magnetic fields cannot be used to impart electron movement to static electrons in a straight conductor to make them jump a barrier to continue their journey and produce current and the 5v we need, per se. You could build an inductive sensor yourself with coils and op-amps and transistors and such to detect the current generated by a magnet attached to your CNC gantry. It would look very cool and steam-punky but such sensors are an entire field of study and whole careers are spent by "top minds" producing proximity switches for us to play with, so I would recommend just getting Proximity Switches.
Software solution:
If you would like to save five dollars on proximity switches by spending a week or two fighting with software then a change in the GRBL code for your CNC machine could fix the problem and eliminate the need for additional circuitry altogether, and you could use your Hall Effect sensors. "Stop switches" are usually normally open and connected to digital pins on the microcontroller. The pins will read LOW when open and HIGH when closed (contacts pushed together). Somewhere in the code there will be a line like "if(mypin==HIGH) then stopdammit();". Just change the HIGH to LOW in whatever programming IDE your system uses. My CNC machine uses Arduino and GRBL. GRBL software for CNC machines is open source and I would be surprised if there was not already a flag you could set to indicate whether high or low means a stop has been reached. My CNC machine does not use any hardware stops. The software is "supposed to" handle that function. Keyword "supposed to"...
FYI2: My application was for an on-off switch for an underwater device where I wanted to be able to wave a magnet over a Hall Effect sensor inside the enclosure with the magnetic field passing through the ABS and turning the device on. I encountered the same conundrum you encountered with your CNC machine so I devised a system where I remove the magnet to turn it on, and place the magnet back on to turn it off. Magnet is attached to the enclosure with a velcro pad at the moment but might build some manner of slide mechanism in the future.
