Clumsy me! Broken USB headset
Erstwhile
Apr 12, 2022
47
I accidentally pulled the cable connected to the stereo headset and microphone from the PCB that has the Volume and Mute function (in which the USB A cable is attached)
The headset cable has a green, a red, a red/green, a blue, and a bare copper wire (which I am assuming is ground)
The PCB solder pads are labeled 1C, 1W, 3C, 1 (C or G), 2R
The red/green wire brought its solder pad with it (no problem as to where it goes)
I am not sure if I am seeing any colored threads still attached to the solder pads. (10x loupe)
Is anyone familiar with this PCB labeling or wire color scheme?
Thanks!
Delta Prime
Jul 29, 2020
2,993
We need to see what you’re looking at.
Can you please take some photos.
As well as the make & model of product the PCB came out of.
Also; do you have & know how to use an multimeter.If not, we will walk you through it. Easy Peezy lemon Squeezy.
john22
Dec 3, 2025
Green wire typically corresponds to audio out (right channel).
Red wire is generally for the microphone (audio input).
Blue wire might be for audio out (left channel).
Red/Green wire can be used for things like volume control or mute signals, based on your description.
Bare copper is likely ground (G).
