CMOS TLC555 reset input
F
Frederic
Hi everyone!
Anybody notices that reset input on a TLC555 can accept a voltage, may be up
to 15V, even if the chip is *not* powered?
Unknowingly, I was driving that pin at 12V on one of my project for months
without apparent effect. The reset input is still working.
The datasheet says Vcc+0.3V for inputs but the equivalent circuit shows the
reset input is directly driving a MOSFET gate. Weird!
Fred
D from BC
Hi everyone!
Fred
Trade yeah!
I'm on a 555 project and it's being used in an unconventional way.
What are the internal comparators input range?
It's not obvious on the Nat Semi LMC555 spec sheet.
I was forced to use 1.5V supply operation specs as used in timing
applications. Trig [email protected] = 0.4V.
Can the Trigger voltage go lower?
Is it a rail to rail comparator?
D from BC
Spehro Pefhany
Hi everyone!
Fred
TI's schematic shows resistors in series with all the inputs (most of
which go to gates, plus Vc which goes to the divider network made from
MOSFETs). It does not show the resistor values or the protection
networks.
http://focus.ti.com/lit/ds/symlink/tlc555.pdf
The abs max input voltage is shown as Vdd. Clearly this can easily be
violated by voltage on the timing capacitor or Vc bypass cap if the
supply voltage falls rapidly at power off.
Have you measured the typical resistor value?
Best regards,
Spehro Pefhany
F
Frederic
networks.
Which resistor?
F
Frederic
D from BC said:
Trade yeah!
D from BC
Good question in return.
Logically the comparators surely can go to ground rail otherwise they would
screw up when the cap is completely discharged at the beginning of the first
timing cycle. Going lower in a probably unknown territory.
For the Vcc rail, I would yes but I don't have any argument, I'll have to
think about this...
Fred
Spehro Pefhany
Which resistor?
One of the ones that is shown in series with the inputs such as
/RESET. Probably they are all the same value. A crude way would be to
measure the input current and divide it into the input voltage minus
the supply voltage. Better would be to find the slope of the line with
a couple of measurements. Obviously, I'm guessing that there is a
protection network living on the other side of the resistors.
F
Frederic
The datasheet says there is ESD protection. I guessed, like you, it would be
some kind of protection like the usual two-diode protection.
But there doesn't seem to be an internal diode from input to Vcc (reason of
my original question)However I'm gonna check below negative rail, if it
clamps at say -0.7V then at least there is a diode there AND an easy way to
figure out precisely the value of the input resistor.
Fred
John Fields
timing cycle.
They do screw up on the first cycle if they're wired up as astables.
That's because the threshold comparator's trigger voltage is at
2/3Vcc and the cap has to charge to that voltage from 0V when it
first starts. Thereafter it only has to discharge to Vcc/3 for the
cycle to start again.
Spehro Pefhany
Fred
Maybe. The protection could be something like a zener, so measuring
the slope of the V/I curve would give the value. The resistor may have
the equivalent of a reverse-biased diode all along its length if it is
sitting in a diffusion well (terminology?) for isolation. Jim T would
be able to comment on the likelihood of this in a CMOS chip.
Best regards,
Spehro Pefhany
John Popelish
Of course, you can fix most of that by using a pair of
capacitors in series across the supply, with the one going
to the positive supply half as large as the one going to the
negative supply. The node between them is the timing node.
This pair will start out at 1/3rd of the supply voltage
when the circuit is powered up. They also act as a bypass
for the 555 supply while doing their timing thing. This
arrangement also cancels out most supply ripple sensitivity
for the 2/3rd supply comparator reference, and half of the
sensitivity for the 1/3rd level, usually eliminating the
need for a capacitor on the reference pin, so it doesn't
even add a component.
John Popelish
If you connect a sensitive current meter in series with the
pin, you should be able to see the onset of the protection
clamping action, as you raise and lower the voltage on the
pin (through the current meter). The protection may be a
zener, not a pair of diodes to the rails.
John Fields
jasen
the data sheet calls it Vs not Vdd
-3 to Vs +0.3 is safe for the device (top of page 3)
0.4 is the minimum level it could trigger at, what's
not mentioned is the effect of the CV pin.
Bye.
Jasen
D from BC
Bye.
Jasen
Yes..the absolute comparator input spec is a clue..But I don't think I
can go on that for proper comparator operation.
I'd like to drive the control pin and trigger pin with near ground
voltages..
By the way, this is not in any application note.
All I know is it will work as low as 0.4V... below that..I dunno..
I've been thinking about the 555 start up behavior from other
posters....
Reminds me of op amp phase reversal when max input levels are
exceeded... .Is that what's happening?
D from BC
John Fields
voltages..
posters....
No.
Here's the equivalent of a 555: (view in Courier)
Vcc
|8
[R]
5 |
VC>-------+----|-\
6 | | >---+
TH>-------|----|+/ | +-----+ 3
| +--|R Q|----------->OUT
[R] | _ _|
__ 2 | +--|S R Q|--+ 7 ___
TR>-------|----|-\ | +-----+ | C---->DIS
| | >---+ O +-B Q1
+----|+/ | E
_ 4 | | |
R>--------|-----------------+ |
[R] |
|1
GND
What is it you want to know?
D from BC
On Sat, 13 Jan 2007 17:39:45 -0800, John Fields
[snip]
Vcc
|8
[R]
5 |
VC>-------+----|-\
6 | | >---+
[R] | _ _|
| | >---+ O +-B Q1
+----|+/ | E
_ 4 | | |
[R] |
|1
GND
k.. starting over...
I'm wondering if my questions are confusing due to traditional 555
usage...Or I'm just missing the boat.. :)
k...I'll put this another way..
What is the CMVR (common mode voltage range) of the internal
comparators? Includes ground? For the TLC555 or LMC555.
Or how about this:
Vs= 12V
Control Voltage Pin = 20mVDC constant
Trigger Voltage toggles between 5mV and 15mV...
Neglecting comparator offset voltage and disregarding everything else
in the 555...
Does the "trigger" comparator still work? Or are these values out of
range (Too low)?
I'd test this in SPICE but I don't trust my 555 model..It's got bugs.
My backup SPICE program only has ideal model..
D from BC
jasen
voltages..
ooh!
I notice they only put 3V pk-pk modulation on that pin with a 5V supply
hmm, doesn't sound good for 1.5V operation
John Fields
[snip]
Vcc
|8
[R]
5 |
VC>-------+----|-\
6 | | >---+
[R] | _ _|
| | >---+ O +-B Q1
+----|+/ | E
_ 4 | | |
[R] |
|1
GND
Or how about this:
Vs= 12V
in the 555...
range (Too low)?
Since the common-mode spec's for the comparators aren't revealed,
this:
"In monostable applications, the trip point on TRIG can be set by a
voltage applied to CONT. An input voltage between
10% and 80% of the supply voltage from a resistor divider with at
least 500-µA bias provides good results."
from the bottom of page 10 of:
probably sums it up.
D from BC
On Sun, 14 Jan 2007 08:45:25 -0800, John Fields
[snip]
this:
Thanks... I didn't see that on the TI sheet.
I've been beating the LMC555 National datasheets too much for clues..
Makes sense too that the comparators CMVR is not in the data table..
It's generally not a spec used directly in timing applications.
I got enough data to get a "good enough" design :)
D from BC
