Coill winding / AC motor construction - book recommendation ?
N
N Cook
I went to main city library and only 8 books on electrical anything
and nothing on coil winding or motors.
Any recommendations on practical teechnique ?
electronic hints and repair briefs , schematics/manuals list on
http://homepages.tcp.co.uk/~diverse
N
NSM
Find a bigger city.
'Audels' has it's faults but will get you started.
N
Charles Schuler
Motor coil rewinding is not recommended for a one-of repair! If you are
really serious, please know that you will make a substantial investment in
tools, materials and personal knowledge.
Yes, I have rewound stator coils and will never do it again! I have never
done a wound armature and know enough to avoid even thinking about it.
N
N Cook
NSM said:
Find a bigger city.
N
Would this be the book ?
Audel Small Electric Motors: Use, Selection, Repair, and Maintenance, 2nd
Edition
Rex Miller, Mark Richard Miller
ISBN: 0-02-584975-1
Hardcover
436 pages
April 1993
PART ONE-Introduction.
1. Motor Repair Tools.
Screwdrivers · Pliers · Hammers · Hacksaws · Wrenches · Other Tools · Meters
and Test Devices.
2. Motor Repair Supplies.
Setscrews · Carbon Brushes · Bushings and Bearings · Shaft Adapters · Rubber
Mounts · Fiber Washers · Rubber Grommets · Replacement Switches ·
Electrolytic Capacitors · Insulating Enamel · Cord · Motor Wiring for
Installation.
PART TWO-Fractional-Horsepower Motors (Basic Types).
3. Small DC and Universal Motors.
Shunt DC Motors · Compound Motors · Permanent-Magnet Motors · Series or
Universal Motors · The Hand Drill · Portable Saws · Repairing a Series
(Universal) Motor · Miscellaneous Information.
4. Split-Phase Motors.
Starting a Single-Phase Motor · Starting a Split-Phase Motor ·
Characteristics of the Split-Phase Motor · Dual Frequency Operation · Motor
Noise and Vibration.
5. Capacitor-Start Motors.
Starting a Capacitor-Start Motor · The Electrolytic Capacitor ·
Characteristics of the Electrolytic Capacitor · Characteristics of Capacitor
Motors · Reversing the Motor · Dual-Frequency Operation · Mechanical and
Electrical Noises.
6. Shaded-Pole Motors.
Starting the Shaded-Pole Motor · Types of Shaded-Pole Motors · Construction
of Shaded-Pole Motors · Performance of Shaded-Pole Motors · Applications of
Shaded-Pole Motors.
7. Three-Phase Motors.
Uses of Three-Phase Motors · How Three-Phase Motors Work · Torque · Motor
Ventilation · Motor Losses · Reversibility · Applications of Three-Phase
Motors.
8. Special Types of Motors.
Understanding the Nameplate · Troubles · Bearings · Three-Speed Motors ·
Instant-Reversing Motors · Severe-Duty Motors · Farm-Duty Motors · High-Slip
Motors · Explosion-Proof Motors · Metric Motor Ratings.
PART THREE-Maintenance and Repair.
9. General Maintenance.
General Troubleshooting Procedures · Maintenance of the Split-Phase Motor ·
Maintenance of Capacitor Motors · Electrolytic Capacitors · The Permanent
Split-Capacitor Motor · Maintenance of the Three-Phase Motor · Maintenance
of Brush-Type Motors.
10. Commutators and Brushes.
The Armature · Magnet-Wire Characteristics · Commutator Maintenance ·
Brushes.
11. Shafts and Bearings.
Motor Shafts · Selection of Bearings · Ball Bearings · Bearing Failure ·
Motor Problems Caused by Bearing Wear or Damage.
12. Switches and Relays.
Overload Protection · Internal (Line Break) Motor Protector · Relays for
Motor Control · Maintenance and Repair of Relays · Electronic Speed Control.
13. Armatures-Stripping and Rewinding.
Checking the Armature · Commutator Removal · Tests on the Commutator ·
Difficult Windings · Replacing the Commutator · Hand Winding, Coil Forming,
and Slot Wedging · Loop Method of Winding · Armature Banding · Testing the
Armature · Automated Armature Winding.
14. Stators-Stripping and Rewinding.
Stripping a Winding · Rewinding a Stator · Mold and Hand Winding · Automatic
Coil Winding.
PART FOUR-Modifications of Motors.
15. Modifying Motors.
Motor Modifications for Shafts · Speed Controls · Modifying AC Motors for
Speed Control · AC Motor Speed-Control Methods · Reversing Direction of
Rotation.
PART FIVE-Motor Selection and Replacement.
16. Motor Selection and Replacement.
Selection of Motor Type · Motor Mounting · Part-Winding Starting ·
Enclosures and Special Winding Treatment · Guide to Selecting the Right
Motor · Installation · Location and Motor Enclosures · Maintenance.
PART SIX-Electronically-Operated Motors.
17. Steppers and Synchronous Motors.
Shaded-Pole Unidirectional Synchronous Motors · Capacitor Start and Run
Bidirectional Synchronous Motor · Single-Phase Stepper Motor (Unipolar
Drive) · Single-Phase Stepper Motor (Bipolar Drive) · Two-Phase Stepper
Motor (Unipolar Drive) · Four-Phase Stepper Motor (Unipolar Drive) ·
Open-Frame Synchronous and Stepper Motors · Reversible Step Servo Motor ·
High-Torque Reversible AC Motor · 3-Wire Stepper Motor (Open Frame).
18. Motion Control.
Disc Magnet Stepper Terminology · Disc Magnet Steppers · Disc Magnet
Two-Phase Stepper Motor · PM Two- and Four-Phase Stepper Motors · Two- and
Four-Phase Linear Stepper Motors · Brushless DC Motors · Ironless Rotor DC
Motors.
PART SEVEN-Motor Terminology.
19. Motor Terminology.
