Recommendation for re-winding transformer?
Do you have a photo of your transformer?
Measurements of the physical size would also benefit.
Just it will give a better idea on complexity of any rewind.
kellys_eye
Jun 25, 2010
6,512
Output transformer or mains supply?
If mains, you can usually source a replacement equivalent (unless you're trying to do a restoration and want an identical replacment) but if it's an output transformer then have a go at rewinding it yourself!
Link shows.......
The 222-C power transformer has the following characteristics:
Primary: 117 VAC
Secondary:
360-0-360 VAC @ 150 mA
50 VAC @ 150 mA
6.3 VAC @ 5A
5.0 VAC @ 2.0A
not a standard run-of-the-mill replacement I would think
14,317
Why do you think the transformer is bad? Transformers (the electrical type :) ) usually are rather rugged.
