Cold light source
Bunchats
Feb 26, 2012
4
Hi to all, I registered because I hoped I might find an answer here. At least a cheaper way of doing it!
I am studying insects and to do that I need a cold light source.
I would like a 12v system so that I can take it in my vehicle and work there under a microscope.
Can I make one. Is there somewhere to buy one cheaply?
Help please and thanks for looking at least.. :)
When you say "cold light source" do you mean a source which does not emit heat, or one with a high colour temperature (which is -- perversely -- called cool, or cold)?
Bunchats
Feb 26, 2012
4
Hi Steve,
Yes, I mean a light that does not emit heat - Thanks
Have to go out again so check back this evening.
14,311
How about an LED flashlight?
If you absolutely need to power it from your 12 V car battery, add a series resistor or voltage regulator between battery and flashligt. However, an LED consumes much less power than a conventional lightbulb (no heat!), so the flaslight's battery will last rather long. Use rechargeable batteries and have a spare set ready. Recharge during the day. I think this is much more flexible than being tethered to the car.
Harald
Bunchats
Feb 26, 2012
4
Harald
OK, thanks for that, I will dig out our flashlight and see if the heat, if any, is acceptable for live insect examination.
JMW
Jan 30, 2012
90
How often do you do this? "Chemlights" may work. They come in a variety of colors including ultraviolet.
Bunchats
Feb 26, 2012
4
Do it 3/4 times a week for an hour or so a time. The light has to be a spotlight for the viewing to be done.
JMW
Jan 30, 2012
90
Well they won't work, the problem with all "cold" sources is they are monochromatic,
Other than white LEDs (depends if it passes your definition of "cold" though)
