Comment about this design...
kebloks
Sep 12, 2006
10
http://www3.telus.net/chemelec/Projects/Power-Supply/Power-Supply.htm
schematics:
will it work?
ante1
Jan 24, 2004
4,136
Hi kebloks,
Welcome to our forum!
Looks good, try it!
audioguru2
Apr 6, 2004
12,022
The resistor from the output to the ADJ terminal of the voltage regulating IC is 240 ohms when it should be 120 ohms so the output voltage doesn't rise without a load, as per the datasheet. Then the value of the voltage adjustment pot should also be reduced to half also.
ante1
Jan 24, 2004
4,136
Hi AG,
Well, Gary built and tested it without any problems!
audioguru2
Apr 6, 2004
12,022
Hi Ante,
Gary made one or two.
The datasheet has a max rating for the IC's idle current which is 10mA for the LM317 in a large case and only 5mA for the more expensive LM117. The reference voltage of 1.25V flows through the resistor which is only 5.2mA for a 240 ohm resistor. Since the max idle current for the LM317 is 10mA then you can expect some of them to have more than only 5.2mA so the output voltage will rise without a load.
Unfortunately, the datasheet shows a circuit with a 240 ohm resistor on its 1st page and that is the circuit most people use. It uses an LM117.
ante1
Jan 24, 2004
4,136
Yes I know what you are getting at; it’s not the first time this discussion has been up!  ;D
Let’s do it your way; let’s change the resistor for a 120R and we’re really safe!  ;)
kebloks
Sep 12, 2006
10
Will it work for 3A?
and... ( from the site )
"NOTE: &nbspR2 is determined by the voltage across the 220 uF Cap.
        (Volts - 1.2)
R2 = -------------
          .015
Any Resistor close to the calculated value should be fine. Its only purpose is for an approximate 15 mA current flow which will create a quite stable -1.2 volt supply. "
does it mean voltage across the cap of the complete circuit?
