Nick Mulder
- Oct 13, 2005
- 43
- Joined
- Oct 13, 2005
- Messages
- 43
a few months back I made this cct so I could control the output of an LDR (or phototransistor) to give me an output that would cover a 0~X Volt range (X could be anywhere from 12V down to zero).
for instance if the LDR output was 2~4V volts I would minus 2 Volts with the bias single gang pot and then amplify by x6 to get 0~12V or by x2.5 to get 0~5V using the scaling dual-gang pot (shown twice).
I didn't have much time to get this cct working and not knowing much about op-amps left me with a couple of not so perfect factors, it was still fine for the application - (16 of them were put together on vero board)
I want to make a PCB version next and would like any advice to stop the following issues:
a. The offset will easily let the output fall into the negative (ie. setting the zero point takes more time than it should)
b. The amplification will range from being unresponsive to sudden changes - its like I turn it half way to get the first half of what I need then 2mm around to get the rest
I'm also putting a LPF on the LDR output to get rid of light flicker from spurious sources - we were getting a 48Hz square wave from it once when a film projector as pointed at it....
I hope the schematic is easy to read, its my first and I'm not sure of conventions.
Please feel free to comment on any other odd bits you may see could be done better.
Any help greatly appreciated,
thanks,
Nick
thanks,
Nick
