compact-flash/ide adapter
H
Hul Tytus
sci.electronics.design
A compact-flash/ide adapter (SD-CF-IDE-A) from dealextreme.com worked well
but only as a master, not as a slave, which is a distinct bother. Anyone know
of an ide adapter that works either way, either from dealextreme or another
dealer?
Hul
G. Morgan
dealer?
Is the other HDD set to 'CS' mode?
G. Morgan
I'm not familiar with CS Mode - could you explain?
On the HDD there is a jumper to move to 'CS', instead of slave or
master. This makes the device select a channel based on it's position
on the cable.
G. Morgan
on the cable.
"Many drives feature an option called Cable Select (CS). With the
correct type of IDE ribbon cable, these drives can be auto configured as
master or slave. CS works like this: A jumper on each drive is set to
the CS option. The cable itself is just like a normal IDE cable except
for one difference -- Pin 28 only connects to the master drive
connector. When your computer is powered up, the IDE interface sends a
signal along the wire for Pin 28. Only the drive attached to the master
connector receives the signal. That drive then configures itself as the
master drive. Since the other drive received no signal, it defaults to
slave mode. "
http://computer.howstuffworks.com/ide4.htm
G. Morgan
Thanks for the explaination. I tried that once but in a bit of a blind
fashion. Another try may not hurt.
If the HDD is on CS and the IDE-flash/adaptor has a switch for it, set
it as CS too. Then the cable with select M or S , the middle of the
cable is master I believe (check me though).
