Compact Flash with Lecroy 93XX scopes?
I have a Lecroy 9384TM scope which works great. It has a slot for a
CardBus compact flash adapter. I have tried a couple of combinations
of CF card / adapter, without success. Has anyone found a combination
of CF / adapter that will work? The Lecroy part is no longer
available, and was very expensive when it was.
Thanks for any feedback. This would likely be helpful to any other
Lecroy users out there.
Sergey Kubushin
Sure it would. I own 2 9354M scopes and would like to use that memory
card...
Hi all,
I have tried it with a 9354AL, a compact flash adapter for PCMCIA
and a 512MB Kingston Compact Flash memory, and it does NOT work. It
seems that only 512kbytes SRAM are accepted on the front memory card
slot.
The next generation oscilloscopes (LC534 and others) do support
this. Check the Lecroy FAQ/Knowledge base to get more info about flash
memories accepted by these new oscilloscope series.
In any case, if you have installed option HD01 in your 93XX
oscilloscope , you can buy one of these cards:
http://jvadillo.googlepages.com/mem001flashcardsharp10mb
Finally, if you just want to get a screenshot and have it in your
computer, only a null modem cable is neede. Check this link:
http://www.jvadillo.com/serialosci/serialosci.htm.
Regards,
Juan Ramón
Check my second hand oscilloscope sale on: http://jvadillo.googlepages.com/
