Ian said:
On all probably 5 or 6 makes of CFL I have dissasembled, they have a
rectifier before the energy storage cap, and hence will run just fine
on DC (340V in the UK).
(though I find a goodly number will run on about half sticker power at
150V, but probably doing bad things to the tube)
I have seen older articles recommending DC operation of CFLs:
http://www.siliconchip.com.au/cms/A_102473/article.html
I have heard that newer tubes require a voltage lower than 340V if smooth DC
is used, because they choose the smoothing capacitor to be much smaller
than that which would be necessary to maintain a steady DC voltage on the
cap with mains input, therefore they expect a lower average voltage than
340V. I can only guess that this is a combination of cost cutting and
measures to improve the harmonic content of the input current.
I have seen an inverter circuit which is designed to drive these newer CFLs,
but it seems very complicated to me, and I would rather find a combination
of CFL type and DC voltage which is reliable without having to replicate
the waveform of rectified normal mains.
http://www.siliconchip.com.au/cms/A_102412/article.html
There is a special model of the Osram CFLs which is called 'facility' and
which is specified for DC operation. Also various ordinary Osram CFLs are
mentioned on some Osram websited as being able to run on DC, though these
websites do not seem to be in complete agreement about which models are
suitable.
They used to have a FAQ which discussed this but they have deleted it, and I
can only find foreign language versions now with google, and a version in
English which is only in google's cache but which comes up 404 on Osram's
website.
http://www.osram.com/pdf/service_corner/DULUX_Sortim.pdf
http://66.249.93.104/search?q=cache:sdxOwF9Fv_wJ:www.osram.com.ro/
(url continued.....) service_corner/faq/general/compact.html
http://www.osram.fr/faq/faqfluocompactes.php
Chris
