Component values are unknown
wounder
Jun 15, 2019
13
I have a circuit consisting of ESP8266,STM and a single relay.
For supplying power to these IC I need an SMPS circuit.
I got a non-isolated buck converter (using VIPER06Xs) as shown but the component values are unknown.
Could you please tell the suitable component values needed for this circuit? I chose this converter because the PCB that I will be planning is small in size.
Voltage needed for ic--
  • ESP = 3.3 V
  • STM = 3.3 V
  • RELAY = 5 V
https://www.st.com/resource/en/datasheet/viper06.pdf
I think you need to supply a bit more info about the project as a whole.
wounder
Jun 15, 2019
13
project simply a smart socket.
figure below gives much details
Audioguru
Sep 24, 2016
3,656
The circuit posted has its ground connected directly to mains electricity so it presents a serious shock hazard and this thread should be closed with the warning.
14,317
Considering that the SMPS module is non-isolated you are completely right.
@wounder : I suggest you use an isolated SMPS for safety reasons. The green area then is safe under this condition. You should not trade safety for size!
You need to know the current drawn by the relay (5 V is insufficient information). The use this our resource for selecting componnet values.
wounder
Jun 15, 2019
13
Could you please provide other SMPS circuit rated(min of output 500mA)
Martaine2005
May 12, 2015
5,318
In post #3, how is this circuit connected to ground?. It looks completely fine to me. Am I missing something?.
Martin
14,487
Martin
agreed
huh ??
and how did you determine that the off the shelf charger he is using is non-isolated ?
Yes, his first cct showed a non-isolated converter … BAD
but the cct in post #3 doesn't and as long as @wounder uses a smps as in post #3 he will be good to go
I'm about ready to clean up this thread stating with AG's screwball post
I think AG and Harald have both missed something
But I await some responses first
Audioguru
Sep 24, 2016
3,656
The Viper 06 Buck Converter shown in post #1 has its ground connected directly to one side of the electricity with no isolation.
14,487
yes, as I said, that one was bad, but his update in post #3 was good :)
