Component values in relativity theory
bob
Has anyone encountered an analysis of the values of electronic
components such as inductors, capacitors, etc at fractional light speed,
where, presumably, mass and size change with velocity?
w4mb
Tim Shoppa
of electronic components such as inductors, capacitors,
etc at fractional light speed, where, presumably,
If you're traveling along with the component and make a measurement,
then you'll see exactly the same component value as you do when you and
the component are at rest.
When I figure out how to attach test leads to a resistor moving at
0.99c, then maybe the value in other frames will become of interest :).
W
Walter Harley
Hmm, quite a challenge. You'd have to coil up a few billion km of test lead
in advance, and as it uncoiled at the speed of light, its inductance would
be changing... it would be heck for AC current measurements. I suppose
unspooling it that fast might make for a bit of triboelectric interference,
too.
That helps explain why they use such darn strong springs in the little
miniclips, though. Never could figure that out.
W
Watson A.Name - \Watt Sun, the Dark Remover\
w4mb
Duh! Relative to _what_? Think about it.
W
too.
Not to mention that the red shift would turn the red test lead into a
black one. The black test lead? Dunmo, maybe IR? :p
Jim Adney
HP did the experiment of taking one of their cesium clocks around the
world on a plane while its twin stayed home. When reunited, the
traveling clock was behind by the amount predicted under general
relativity.
