cardholderone
- Jan 3, 2014
- 3
- Joined
- Jan 3, 2014
- Messages
- 3
Hi all,
new member here, working on a project that I have been thinking about for quite a while. I wanted to build a Infrared night-vision system, like so many seen on the web, using a composite ir cam and old camcorder viewfinder... well, it works, but not too well. The cam I was using was a very cheap cam. Now, I decided to upgrade the cam. I found a new one and really liked the image it put out. However, when connected to the composite input of my viewfinder, the image is, how to put it..., overly rich... or just plain awful. I noticed the composite output of my working cam was +/- 0.6V and the output of this new cam is about 3v! I cannot know why this cam puts out such a high signal. I tried using a resistor to ground on the output to try to knock this down some, and it did. Picture is a little better, but don't know what the long term implications of such a rogue resistor in the output may do to the rest of the cam. Long story short, (too late), I need to know it this is a common output for some composite sources, and if sinking some of that signal will actually hurt the cam.
Cam: Ir off brand 8v setup...
Viewfinder: Jvc crt type, also 8v
powered entire setup using lm317 regulator putting out about 8.2v from 12v
