Computer Project - Grounding Question
Eight
Aug 13, 2004
Hi there,
I'm currently planning (and to an extent, building) a simple computer system based around a Z80 cpu.
Initially, I plan to power everything from standard batteries and when finished, I hope to make a simple case for it.
Most of the electronics side I know enough about but am a little lost on the question about grounding though.
If the circuit board and components all link to a central grounding point - should I be connecting this to a metal frame? Or for devices powered by DC batteries, is it enough just to put in a plastic case? I know that metal frames/chassis/cases (whatever) help with interference etc. but aside from that, should I do it?
I'm guessing things would be different if the device was connected to a mains power supply?
I'd really appreciate it if someone could help me out on this - or point me in the right direction. I've searched the web but found nothing that has really clarified things to me.
surajbarkale
Aug 5, 2004
256
You should not connect signal ground to the chassis for a mains connected equipment. There is a seperate Earthing lead in mains supply for it. Just design your PCB right & you won't have trouble of interferance unless you are in industrial envoryment.
MP1
Dec 7, 2003
3,397
Eight,
It really depends upon what you will use the computer for. I use metal cases to protect against radio interference and I use the case as a ground to the battery system. This is also the industry standard for instrumentation.
Hope it is helpful.
MP
