How to connect 12V realy to a LED using resistor
A asifpeechamgod Sep 7, 2017 1 Joined Sep 7, 2017 Messages 1 Sep 7, 2017 #1 How to connect 12V realy to a LED using resistor
Harald Kapp Moderator Moderator Nov 17, 2011 14,313 Joined Nov 17, 2011 Messages 14,313 Sep 7, 2017 #2 https://www.electronicspoint.com/resources/got-a-question-about-driving-leds.5/
Robert_fay Jun 15, 2017 124 Joined Jun 15, 2017 Messages 124 Sep 7, 2017 #3 Something Like This. If you need to calculate the resistor here is a calculator I use. https://www.digikey.com/en/resource...ors/conversion-calculator-led-series-resistor
duke37 Jan 9, 2011 5,364 Joined Jan 9, 2011 Messages 5,364 Sep 7, 2017 #4 If you have a mechanical switch, you do not need a relay.
Robert_fay Jun 15, 2017 124 Joined Jun 15, 2017 Messages 124 Sep 7, 2017 #5 duke37 said: If you have a mechanical switch, you do not need a relay. Click to expand... True, But you need something to run control your relay. This switch could be replaced with a microcontroller, The relay could be run off a different circuit etc.
