My question is if I can have a simple circuit consisting of a rechargable LIPO, led, switch, and resistor in one contained circuit, then from the - and + of the Lipo also connect a magnetic pogo adapter to recharge the battery. Would I just have to make sure the switch is turned off before connecting to charge? Or would this even be a problem. My attached picture is the circuit I’d like to run. I’m trying to fit this into the smallest possible space. So I need to ditch the charging module board. My first design had the Lipo connecting to the rechargeable Lipo module directly via jst. The charging board has + and - holes to connect your circuit to after connecting the battery, so I soldiered the LED, switch, and resister circuit directly to that board. But the circuit was too large with the battery and Lipo recharging module all together. So I had the idea to keep the charging module outside of the main circuit, using magnetic pogo adapters. That way I save space and can just attach it outside the device in a sort of special charger that I make with the module. Any issues with this?
