Connecting 200 LEDs to AC (120V)?
H
Homer
Hi All,
I am planning to remove the light fixture from one of our rooms and put
200 LEDs instead. LEDs are going to be:
Reverse Voltage:5.0 V
DC Forward Voltage: Typical: 3.4 V Max: 3.8V
DC Forward Current:20mA
How can I connect them all to a AC outlet (110V or 120V? in Canada).
I believe I need to put a "bridge rectifier" to prevent blinking and
they should be mixture of parallel and series.
Thanks if advance,
Homer
H
Homer J Simpson
Why?
H
Homer
The same reason that people put Halogen instead of old bulbs.
it's cool and looks better (in my point of view)
Don't top-post. Just buy LED bulbs. Don't build your own. Did you ask
how to connect tungsten wire by yourself to 120V instead of buying
incandescent bulbs?
Joel Kolstad
incandescent bulbs?
That's not really a fair comparison. A fair comparison would be someone
asking to build their own (120V) Chrismahanukwansika lights by stringing
together a bunch of low voltage (e.g., 6V) bulbs...
John Woodgate
incandescent bulbs?
Well, no, you wouldn't, because you can't buy vacuum in small
quantities. (;-)
H
Homer J Simpson
LED's aren't rated to go open circuit on 110 VAC. I'd use a transformer.
Yes, you'll need a bridge rectifier unless you wire them back to back which
means twice as many.
petrus bitbyter
Homer said:
Hi All,
Thanks if advance,
Homer
Four strings of 25 LEDs in series each with a 1k2/1W series resistor. These
strings in parallel and connected to the rectifier.
petrus bitbyter
Bob Myers
John Woodgate said:
Well, no, you wouldn't, because you can't buy vacuum in small quantities.
You USED to be able to, though...I remember the local
drugstore had small glass vials of vacuum available for sale,
right next to some electronic thingy that was supposed to be
able to test them and (I guess) tell you if the vacuum inside
them was still good....
Ah, those were the days...
Bob M.
Genome
Homer said:
Hi All,
Thanks if advance,
Homer
I do not believe that you would be able to connect 10 Leds together and make
them look good, let alone 200 of them.
So, before I am interested, I would like to see some aesthetic proof of
concept.
DNA
colin
Homer said:
Hi All,
Well at the risk of telling you how to do something that might get you
electricuted if you dont know what your doing ...
You could try and string 25 leds in series, this gives 90v fwd, youl have 8
of these strings
conect them in parallel pairs, then conect two of those pairs in anti
parallell
add a series resistor wich I estimate about 250 ohms, but might be best to
start with say 1k
repeat for the other 4 strings.
conect to safety isolated 115 supply, stand well back, push switch with a
long broom,
.... fetch fire extinguisher, wish youd got some1 watching at a safe distance
to ring for ambulance ...
Colin =^.^=
Genome
Exactly, but that is just your own perception of things. I also have a large
volume of empty head and would have problems with selling it due to the
packaging.
However, I am sure that you might be able to create the experience.
NOM - No Offence Meant
DNA
Yes, I know about the Governers attempted homosexual adventures with what
turned out to be a woman. Is it relevant to your 10% or your new request for
15%?. Is it relevant that your wife makes a really poor man?
I can get this built next door. Ugly Bitch.
This e-mail in no way represents the opinions of any people who might be
made to look bad if they were associated with it unless you were the person
who was meant to receive it in the first place which is OK because we have
more dirt on you than you would care to imagine and we'll make some more up
and it will stick.
If you have received this e-mail in error then please delete it immediately.
Do not even consider the possibilities. The consequences are something you
do not need to deal with.
Thank You
BobG
120 x 1.414 gives 170V peak after the rectifier. So I'd try 4 strings
of 50.
Michael A. Terrell
quantities. (;-)
Buy? What, are you crazy? When I was a kid we had to make our own
vacuum with homemade hand cranked vacuum pumps! Of course, the jerry
rigged diffusion pumps were a lot harder to crank, to finish off our
home brew CRTs!
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
John Woodgate
dated Wed said:
When I was a kid we had to make our own vacuum with homemade hand
You had hand-cranked vacuum pumps? We had to get six kids into line to
suck simultaneously.
Simon Dice
colin ha escrito:
long broom,
Colin =^.^=
I have conected 5 strings of 34 white LEDs (5mm) to a rectifier bridge
with a current regulator (LM317HV)(for each string) and it works fine...
petrus bitbyter
These strings in parallel and connected to the rectifier.
petrus bitbyter
Oops. 200 LEDs require 8 strings of 25.
petrus bitbyter
N
nospam
Transformers are not rated to go open circuit on 110 VAC either.
Michael A. Terrell
Only six? That must have really sucked!
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
