connecting Visonic DL-125C to a Napco Gemini P3200
Mark Davis
I need a bit of advise on connecting the Visonic DL-125c to my Napco
Gemini p3200.
My question comes in reguards to power. Shall I connect it to the aux
power output on the panel? Or connect it the way other things such as
the siren driver appear to be connected?
thanks
Mark
G. Morgan
On 13 Nov 2004 17:52:02 -0800 "Mark Davis"
used 9 lines of text to write in newsgroup: alt.security.alarms
Gemini p3200.
The simple way is to hook up terminals 5 & 14 from the 3200 to the
dialer as shown in figure 6 here: http://tinyurl.com/6bsdc
Since you stated you have a siren driver, I'll assume the relay jumper
is cut for dry contact operation. This way requires no programming,
but you'll only get one event (burg. alarm) reported to the dialer.
To utilize the dual event reporting capability would require a hookup
shown in figure 5, and require a separate SPDT relay to activate from
the bell output and the other from the AUX contact. (that is, if the
AUX contacts are not in use already)
Robert Bass
Hi Mark,
Wire the + & - 12VDC input on the dialer to terminals 13 & 14 on the Napco
Gemini panel. Connect channel 1 trigger on the dialer to terminal 5 (Burg)
on the Gemini panel. Wire the channel 2 trigger to terminal 8 (Aux).
Regards,
Robert L Bass
Bass Home Electronics
2291 Pine View Circle
Sarasota · Florida · 34231
877-722-8900 Sales & Tech Support
http://www.bassburglaralarms.com
