contactless temp.measurement
Dejan Durdenic
I need to measure temperature of the bare copper wire. The wire
moves, so only contactless methods apply. IR pyrometers are not
reliable, due to surface reflections and (possible) small diameter of the
wire.
ANY suggestions wellcome...
regards
Dejan
Spehro Pefhany
wire.
Can you measure the resistance of the wire itself? Failing that, there
are more sophistimicated methods that use fluorescent material painted
onto the target and fibre optics. Not cheap. There are crude/cheap
melt stick methods you might be able to use (but you might have to
view the wire with some appropriate optics to determine the melting).
Best regards,
Spehro Pefhany
John Woodgate
I read in sci.electronics.design that Dejan Durdenic
wire.
Can you measure its resistance? You would need to establish some
calibration, using a non-moving wire and a thermocouple thermometer or
similar.
CFoley1064
wire.
regards
Dejan
Before you give up on contact-type measurement, you may want to consider either
swaging in and/or using thermally conductive adhesive to affix a 34AWG
thermocouple bead to the wire. The 34 AWG T/C wire could move along with your
copper wire, and would not be much of a heat sink if it was done carefully.
You could then use any standard handheld T/C meter (9V battery-operated,
electrically isolated) to read the temp of the wire. This works well for
measuring nichrome wire temp.
The only other method I could suggest would be to infer temp by reading the
voltage drop across the wire while also reading current, inferring resistance,
and then inferring temp -- full of approximations, not too accurate.
Good luck.
Chris
W
Wieslaw Bicz
"Dejan Durdenic
wire.
regards
Dejan
I would suggest to measure speed of sound in the wire. This depends on the temperature of the wire
and can be made contactless.
But requires some development work.
Wieslaw Bicz
---------------========== OPTEL sp. z o.o. ===========---------------
------===== R&D: Ultrasonic Technology/Fingerprint Recognition ====------
ul. Otwarta 10a PL 50-212 Wroclaw Tel.:+48 71 3296854 Fax.:+48 71 3296852
--------==== mailto:[email protected] -=- http://www.optel.pl ====-------
Rene Tschaggelar
Unfortunately the speed of sound also depends on the tension of the wire.
Copper get harder when is is bent, this means the speed also goes
up with increased use of the wire.
Rene
W
Wieslaw Bicz
This is partially true, but this (and many other) influences can be excluded
using many methods.
I have proposed this, because I have already some ideas and some experience,
that can be used here.
From my point of view such measurement is realistic, but this will be not a
simple project.
Wieslaw Bicz
Dejan Durdenic
To make the things more clear - the wire is moving.
Actually, it's the wire production line, where the wire
preheats before being covered with plastic insulation.
So, no contact can be made with the wire. It runs quite
fast - can be a few m/s.
regards
Dejan
W
Wieslaw Bicz
"Dejan Durdenic
regards
Dejan
I have assumed this and this was the reason, why I have proposed
acoustic method.
It requires development, but resulting device can be relatively simple.
Wieslaw Bicz
3296852
Spehro Pefhany
You don't say the diameter of the wire, but if you really need to do
this, I'd look closely at dual-wavelength infrared measurement.
In fact, you can probably get very good control of your process by
just applying a known amount of heat, at a known speed, for a known
diameter of wire.
Best regards,
Spehro Pefhany
Dejan Durdenic
Are you interested in some kind of co-operation on this problem?
If yes, we can discuss details over e-mail...
regards
Dejan
Dejan Durdenic
It can be pretty low - and even stranded...
diameter of wire.
That's not the problem - the wire is pre-heated via HF inductor, but the
customer wants closed loop regulation of the wire temp. Sorry - the
customer is ALWAYS right ;)
- Dejan
W
Wieslaw Bicz
"Dejan Durdenic
regards
Dejan
Yes, I am interested. We can discuss the possibilities directly.
Wieslaw Bicz
3296852
Phil Hobbs
Dejan Durdenic
- Dejan
My suggestion would be to use the schlieren effect--as in mirages. Run
a beam from a diode laser just above the wire, and detect its wiggling
around via a quadrant photocell with differential detection. This will
be independent of the hardness and surface emissivity of the wire, which
the other suggested methods are not. Assuming the air flow near the
wire is laminar, the schlieren effect will depend on the temperature
gradient, which in turn will depend on the rate of conductive heat loss
from the wire. Thus for wire of a given diameter, you'll get a good
wire temperature measurement.
Cheers,
Phil Hobbs
R.Legg
Measure the temperature of the last hardware in contact with the
moving wire; minimize the difference by controlling the environmental
temperature.
RL
F
Fred
- Dejan
What's the temperature range of interest for this wire?
Dejan Durdenic
Fred said:
"Dejan Durdenic @zg.htnet.hr>" <dejan.durdenic<remove_this> wrote in message
100-150 deg.C
- Dejan
Dejan Durdenic
temperature.
RL
The subject was pretty clear - "contatcless temp. measurement"...
regards
Dejan
F
Frithiof Andreas Jensen
Beware: Quite frequently, the customer thinks he/she "needs" something
without understanding the whole package of consequenses. There is
significant commercial risk involved in bastardising a proven product to
implement some "nice to have but only one guy ever wanted it"-misfeature
that the customer will quickly weasel his way out of once the costs become
clear!
Mac
After reading your post I read up on this a little bit. It sure sounds to
me like the best bet mentioned so far. It is contactless, and doesn't
require the wire to fill the field of view. Emissivity is less of a
problem with the dual wavelength setup than with single wavelength
techniques. And I don't see why reflections can't be eliminated as a
problem with proper shading of the measurement area.
diameter of wire.
Best regards,
Spehro Pefhany
Mac
