Contract circuit board maker source?
Roger Johansson
Michael A. Terrell said:
Three switches on the door is the usual setup. Two to keep it from
working with a warped door and the third is a fail-safe.
Okay, but it shouldn't be any problems to rearrange whatever switches
there are for most people in this newsgroup.
The harder part can be the sheet metal work. if you are not used to
mechanical work.
Lord Garth
mechanical work.
How about simply turning over a standard unit .... Then see if the
control panel and the handle can be re-inverted. The lazy susan,
now that's a problem!
Roger Johansson
I thought about suggesting that, but there are problems with that
solution.
The rotating mechanism would have to be changed so you can hang the food
from it somehow. And turning the display and other stuff upside-down may
not be a trivial task.
Rich Grise
I can't be too difficult to rebuild a standard model if you really need a
right hinged micro. Some metal sheet working, creating new hinges on the
other side, turning the old door upside-down and moving a door-closed
electrical switch to the other side. Maybe easier, and cheaper, than
finding and importing one.
I know. It's almost trivial.
I don't want to make ONE, for ME.
I want to make 1,000,000,000, and sell them for $99.00 apiece, and
bank $0.99 per each - I think I could live fairly comfortably for
the next 50 or so years with 99,000,000.00 in the bank. :)
Cheers!
Rich
