Controling DC Fan Speed via Voltage
Tanha
Oct 14, 2016
6
I want to control a 12 volt DC fan speed via its voltage. I have a potentiometer which is 50 ohms, 5 watts.
I connected 12 volt from power supply to the left terminal of potentiometer, and the negative from power supply to the right terminal of potentiometer. I connected the middle terminal of the potentiometer to the positive wire of the fan. (I connected negative wire of the fan to the negative of power supply.)
The fan's speed is controlled successfully from 0 up to its full speed.
But the problem is that the potentiometer heats up.
1. What can be done to prevent this heating up?
2. Does this heat-up show that I have done something wrong?
3. How much heat is ok?
Good luck
Ghobar
Minder
Apr 24, 2015
3,561
Buy one of the $5.00 PWM controllers on ebay.
M.
Tanha
Oct 14, 2016
6
Let's confine the debate to what has been posed in the first post.
JerkStore
Oct 14, 2016
14
Nothing really wrong, just inefficient. You are using the pot as a variable voltage divider to vary the voltage at the motor and control speed. When the motor is running at lower speeds most of the voltage drops across your pot and since it's just resistance most of your power is being converted to heat. A more efficient system would use PWM as the prior message says. A simple one can be made with a 555 timer and a few discrete components
Then the answer is no, you cannot reduce the heat produced. You could use a larger potentiometer which would not rise in temperature as much, but the same amount heat would still be produced. This is only one of the reasons a potentiometer (actually a variable resistor) is not the way to do motor speed control. The second is that changing voltage changes the torque and does not work well for low speeds. And the third is that you are wasting energy.
A PWM controller solves all three of these problems.
Tanha
Oct 14, 2016
6
Can you refer to a really simple tutorial for building a pwm controller?
JerkStore
Oct 14, 2016
14
That's about as simple as it gets. This will drive a small DC Motor but if the motor requires too much current you will have to drive it with a transistor at the output.
Tanha
Oct 14, 2016
6
It is worth noting that at present I am controlling the fan with the potentiometer as a variable resistor. It reduces one third of the speed.
Tanha
Oct 14, 2016
6
Is there different kinds of 555 timer (for example, NE555N, CMOS, etc.)?
If yes, what kind do I need?
(The web page you referred me says nothing that I can find the answer.)
There are many suppliers of the venerable 555, and there are many variants.
I can't see any particular reason that any of them wouldn't be suitable, excluding any power supply voltage issues (just make sure you have a power supply compatable with the 555..
Tanha
Oct 14, 2016
6
Please explain more: what are power supply issues? what are the specifications of a power supply that is compatible with the 555?
(My power supply is desktop computer's PSU which has both 12 volt and 5 volt.)
There is a maximum and a minimum supply voltage for any device. Ensure that the 555 you get is ok for that voltage.
In your case, 12V will be fine for any normal 555.
