Controlling Agilent 8510C with Matlab
awanha
May 5, 2023
6
I want to control Agilent 8510C with Matlab. It is connected through GPIB-USB with my laptop. I have tried below code to set the start frequency and to change the Marker 1 position, but i am unable to commicate. Please advice if code is ok or do i need to change something.
omPortName = 'COM3';
sport = serial(ComPortName);
sport.Terminator = 'CR/LF';
% Set Timeout
sport.Timeout = 10.0;
% Open virtual serial port
fopen(sport);
fprintf(sport, '++ver');
ver = fgets(sport);
disp(ver);
fprintf(sport, '++auto 0');
fprintf(sport, '++eos 0');
fprintf(sport,'CORRON'): %Turn on calibration
fprintf(sport,'CALS1') ; %Select calibration #1
fprintf(sport,'STAR 6E9');
%fprintf(sport,'MARK1 6E9');
% Close port
fclose(sport);
Delta Prime
Jul 29, 2020
2,991
You again. A belated welcome to maker pro.:)
Do you have the appropriate driver?
Agilent 8510C Analyzer
Certified LabVIEW Plug and Play (project-style) Instrument Driver
awanha
May 5, 2023
6
Thank You for your support.
Got trapped in doing this stuff. Found out the port was wrong. Now i can send commands to NW analyzer but still trying to read S-Parameters or Marker position.
bidrohini
Feb 1, 2023
218
The code you provided seems to have a minor issue with the variable name. You define the serial port name as omPortName but later refer to it as ComPortName when creating the serial object.
To fix this issue, you can update the code as follows:
comPortName = 'COM3';
sport = serial(comPortName);
% Set Timeout
fopen(sport);
ver = fgets(sport);
disp(ver);
fprintf(sport,'CORRON'); % Turn on calibration
fprintf(sport,'CALS1'); % Select calibration #1
% Close port
fclose(sport);
Make sure that the COM port number (COM3 in this case) matches the one assigned to your GPIB-USB adapter. Also, ensure that you have the required drivers installed and configured for the adapter.
Additionally, please note that the commands CORRON, CALS1, STAR, and MARK1 are specific to the Agilent 8510C network analyzer. Double-check the documentation for the analyzer to ensure you are using the correct commands and syntax for your desired functionality.
awanha
May 5, 2023
6
% Set Timeout
fopen(sport);
ver = fgets(sport);
disp(ver);
% Close port
fclose(sport);
Thank You. There was port issue, in Agilent 8510C we have two HP-IB ports and I was using the wrong one. Now, I can send the commands to the VNA but when it comes to getting values from the VNA, its not working. I want to read S21 parameters or just Marker1 value to be sure that i can read from NA. Below is the code snippet, Please any advice on it.
fprintf(sport, '++auto 1');
fprintf(sport,'FORM4');
fprintf(sport,'MARK1;OUTPDATA');
%fprintf(sport,'OUTPRAW1');
%fprintf(sport,'S21;OUTPDATA');;
pause(10)
fprintf(sport, '++read eoi');
d=fgets(sport);
disp(d);
fclose(sport);
awanha
May 5, 2023
6
pause(10)
d=fgets(sport);
disp(d);
fclose(sport);
Finally i am able to get one S21 value but i want for a whole sweep. I am using below code, first of all this POIN command does not seem to be working as even i reduce its value, the number of S21 parameters shown does not reduce. Also i am getting below warning. Please any advice on how to calculate S21 for a whole sweep with defined numbers of points.
Code:
fprintf(sport,'CHAN1;S21;LOGP;POIN51;');
fprintf(sport,'SING;');
fprintf(sport,'FORM4;OUTPFORM;');
Warning: The input buffer was filled before the Terminator was reached.
