Controlling power mosfet
3eprabu
Aug 12, 2015
5
Guys need some help here . Im using a irf830 power mosfet to control a dc light , but for some reason i can't control the mosfet via the gate . The light turns on automatically without even supplying signal to the gate . I connected the source terminal to the negative of the battery , one side of the light is connected to the battery and the other is connected to the drain of the mosfet . I tried the same connection using a transistor and it worked fine . totally confused . need some help PLZ . I have tested the mosfet using a multimeter and its working fine .
Gryd3
Jun 25, 2014
4,098
Please link the part# and a diagram to confirm which pins you are using.
Arouse1973
Adam
Dec 18, 2013
5,178
You may need a pull down resistor on the gate to discharge the internal gate capacitor. Show us a circuit diagram.
Adam
3eprabu
Aug 12, 2015
5
Adam
Thanks Adam , I added a pull down resister and its working fine .
My question now is , will this pull down resistor effect the PWM signal I'm going to supply to the gate ? I'm planning to build a light dimmer with the mosfet .
Thanks in advance .
The resistor can probably be 100K or even 1Meg, and at that level It will not affect the PWM signal.
I wouldn't. Do you have another source of power?
Arouse1973
Adam
Dec 18, 2013
5,178
Thanks in advance .
As Bob kindly chipped in with the answer I agree with Bob.
Adam
