Convergence Problem - Mitsubishi 45" PTV Model # VS-45603
Hello:
I have a Mitsubishi 45" PTV Model # VS-45603 Chassis # VZ5 in my shop
which has a convergence problem. The convergence is off Horizontally
and vertically in all areas of the raster for all colors. The customer
menu convergence adjustments do not move the crosshairs in any
direction for any color. I am not familiar with this chassis and don't
have service data for it. I have data and experience on the VZ2
chassis. This VZ5 chassis uses 2 STK392-110 ICs mounted on a board on
the left
side (As viewed from the rear) of the plastic tray. The signal board
is in the middle, and the deflection/PS board is on the right. I have
a data sheet on the STK392-110s from Sanyo, but I don't knwo what the
proper voltages are for the pins. What are the common causes of this
problem? Also, I would appreciate a scan of the convergence schematics
and powers supplies for the convergence circuitry. Thank You!
Robert McPherson Louisville, KY 502) 367-9324 OR (502) 298-6997
K
kip
Change those STK,s and check for open fuses close by.
kip
