Convert 0-30V 3A PSU to 5A or more
faizanbrohi
Dec 2, 2005
203
THe TIP 31A is a change , the Two Paralleled 2N3055 is a change and the UA741 right..
I am making the 3A one , which value of capacitor do i use.
The Picture of my another heatsink is as follows.with and without fan
audioguru2
Apr 6, 2004
12,026
This topic is about modifying the project for 5A of current.
The "Projects Q/A" forum has the topic about modifying this 3A project to work well and reliably. I posted a recommended parts list there many times.
The supply voltage rating of an ordinary 741 opamp is 36V absolute max and is the same for the TL081 opamps in the original project. This project with a 30VAC transformer and low load current has a supply voltage for its opamps of 50VDC. That is why I recommend OPA445AP high voltage opamps.
faizanbrohi
Dec 2, 2005
203
audioguru said:
The TL081 and most other opamps have an absolute max supply voltage rating of 36VDC. The project with your 24VAC transformer will have a supply voltage total of about 40VDC when it has low output current. A 741A opamp and a few others have a max supply voltage of 44V and the OPA445AP has a max supply voltage of 90V
You Said this earlier for the 3A PSU and by the way how is the heatsink for the 3A PSU.
audioguru2
Apr 6, 2004
12,026
A 24VAC transformer will not allow this project to make more than only about 25VDC at 3A or 5A. The project needs a 30VAC transformer and high voltage opamps to make 30VDC at full current.
faizanbrohi
Dec 2, 2005
203
Okay i will ust test it using the transformer . 24VDC , only testing , after everything is complete i will change it ok
Roomi
Aug 1, 2004
134
Hi Friends,
        Has somebody made this circuit using TL431 or TL432 instead of zener diode????
I need the schematic urgently. Any help will be appriciated...... 8) :)
audioguru2
Apr 6, 2004
12,026
Hi Roomi,
Welcome to our forum. ;D
Good idea!
The TL431 or TL432 adjustable voltage references are much better than the D8 zener diode and the project would be better with one. R4 in the project would power it and two resistors must be added to set its voltage to 11.2V.
The schematic for the project modified to work well and with up to 5A output has been posted in this thread by at least two people.
Roomi
Aug 1, 2004
134
I have read all 22 posts here but couldn't find the schematic with TL431 or TL432. Please provide me the link..... ???
Roomi
Aug 1, 2004
134
The problem is that here in my place low current 5.6V zener is not available.So i am thinking about the second way... ???Here is another idea which i haven't been tested but think it will solve the problem of output voltage going down.Making R6 variable(27K) and by adjusting the pot greater than 10K we can increase the output voltage of OPAMP.What do you think guys... 8)
audioguru2
Apr 6, 2004
12,026
A 5.6V, 1W zener diode is tested at 45mA and a 1/2W one at 20mA. They both work fairly well at only 10mA and U1 can supply 10mA without getting too hot, so use 560 ohms for R4 in the original circuit.
Niksun
Aug 29, 2006
16
I am a beginner in actually "messing" around with electronic circuits but have been around them for a while and am very comfortable tinkering around.  For example, I've been working with FPGAs for several years, albeit mostly on the software side of things.  I have also made a robot which wanders around avoiding obstacles via infrared.
In any event, I am very interested in building the power supply as it is in its current state (0-30VDC, 0-5A, I believe).  I am interested in having a voltmeter and ammeter in place (will build it in a case and have these on the front of the case), and am interested in having a dual power supply.  Now, does anyone have the "final" schematic for this thing (including the voltmeter, ammeter, and dual power supply requirements), perhaps also a "detailed" parts list (i.e. a volt rating for all the capacitors, heatsink requirements, fan requirements, etc).  Even better would be like a parts list from mouser or something in order to ease the ordering process.  I know, this may be asking too much, but I figure why not ask.  You folks are really helpful from what I've been reading, and this seems to be a very cool place to wander around!
I have been reading a whole bunch about this stuff lately and seem to be moving from the software side to hardware.  I have messed around with simple circuits (built a battery charger to recharge store-bought alkalines at ~65mA, a MIRT, also one of those rotating persistence of vision LED thingies, etc).  I would very much like to build this power supply.  Any suggestions for a beginner?
Thanks for your help.
--Niksun
TriggerShock
Sep 14, 2006
3
Hi I'm thinking about building this PSU but I want to make a dual supply that I can switch to 0-60V but I'm a little confused on what kind of transformer I should use.
I have read that you can make a dual output using seperate windings, i'm not sure how to hook up the secondary windings. I know that they would each need there own rectifier, filter capiciter ect.. Hammond makes a 60V center tap transformer that is in my price range (model 182R30) Can I use this transformer to achieve a dual supply? If not, what kind of transformer could I use? (specs would help) I'm hoping to keep it as a single transformer rather then two completely seperate transformers.
In addition if I cant use the Transformer I mentioned above for a dual supply, how about a Bipolor supply using the center tap as a common ground?
This would be for the improved 0-5A 0-30V PSU
Thanks in advance,
Trigger
audioguru2
Apr 6, 2004
12,026
Hi Trigger,
The Hammond 182R30 has two completely separate 30V secondary windings. Each winding can power one of these 0-30V/5A power supply projects and you can connect the regulated outputs of the projects in series for up to 60V output.
indulis
Nov 21, 2005
488
Good idea!
and
I looked at the zener diode D8 in the negative feedback loop of opamp A1 and they perform very well when the zener is a low current type and the value of R4 is reduced to provide it with enough current. It would be difficult to include a TL431 or TL432 in the same opamp circuit and I don't think it will perform as well by itself.
So which is it??
Adding a TL 431 to this circuit is VERY, VERY SIMPLE!!! A1 can even be used as a buffer. Your joking when you say a non-presision, non-temperature compensated zener will work better than a "real reference" ... right??
audioguru2
Apr 6, 2004
12,026
The voltage reference circuit can be re-wired to use the TL431 precision IC instead of a " non-presision, non-temperature compensated zener" like this:
ante1
Jan 24, 2004
4,138
Hi AG,
If you like to improve the stability of the zener D8 it is possible to add a standard rectifier diode (i.e. 1N400X) in series (head on).
Niksun
Aug 29, 2006
16
OK, so does anyone have a "latest" schematic for this puppy (the 0-50V, 0-5A)?  Also, some of us are still learning and may need more specifics in terms of what parts to heatsink and what parts to get, so perhaps a list of parts would be nice.  Thanks a bunch and keep up the great work!
--Niksun
