convert 110v dc to 24v dc
elshorbagy01
Apr 9, 2016
14
hello everyone, I need help
I have an instrument that works at 24v dc and I have only source of 110v dc
What can I do?
Minder
Apr 24, 2015
3,561
What is the nature and/or origin of the 110vdc?
M.
Minder
Apr 24, 2015
3,561
What is the max current requirement of the 24vdc?
M.
Minder
Apr 24, 2015
3,561
I have done this with a simple resistor, 24v zener diode and electrolytic capacitor.
It was on a mobile crane generator that output 240vdc and I needed 12v or 24v for a regulator circuit.
This worked a treat.
You have to calculate the value of the series resistor for the max 24vdc load.
For 110vdc you will need a 12w 550 ohm ww resistor approximately, it is not the most elegant way, but uses the least components.
M.
elshorbagy01
Apr 9, 2016
14
M.
may you draw that circuit
Minder
Apr 24, 2015
3,561
Place a 100uf capacitor across the 24v zener diode, V2.
M..
duke37
Jan 9, 2011
5,364
Many switch mode power supplies work on AC but the first thing they do is to rectify the AC to DC. They should be able to run on DC without modification.
cjdelphi
Oct 26, 2011
1,166
I'm thinking a resistor divider / zener as mentioned which powers a microprocessor then use a switching method to an inductor to buck covert it
Tricky
elshorbagy01
Apr 9, 2016
14
Tricky
how to calculate the inductor and resistor to get 24v out of 110v
duke37
Jan 9, 2011
5,364
Making a switch mode supply is complicated and not for the novice.
Why not use a standard 110V to 24V switch mode supply (buck convertor) as I mentioned earier?
elshorbagy01
Apr 9, 2016
14
i searched for that and i didn't find that rating,
only max 40v dc buck convertor
if you find one plz tell me
AnalogKid
Jun 10, 2015
3,058
You can buy switching regulator modules that handle this input voltage range, or build one with a control chip fro Linear Technology.
ak
duke37
Jan 9, 2011
5,364
I found several on e-bay 100-240V in to 24V DC power supplies.
They specify 50 or 60 Hz input but I would expect them to work on DC.
The advantage of these is that they come in a insulated case.
I do not know how to copy the pictures here.
