converting circuit from relay to something else ?
exxos
Hi all,
A simple switch uploaded here
http://www.aqtq39.dsl.pipex.com/temp2/switch.jpg
Bascially 100VDC unregulated supply rail. Drops 72V via a zener to power a
24V relay. Capacitor just to add some small smoothing to prevent the relay
from buzzing.
While the relay is turned ON, it connected the output to the 24V supply via
a 100K resistor.
When the relay turns OFF it shorts the output down to ground.
Sounds really simple, though I have been trying for the past 2 days to
convert this to a simple transistor circuit. To which after several attempts
given up so decided to ask here before I use the relay verson to see if
anyone can suggest a simple circuit which would do the same.
Chris
exxos
Dave said:
I would suggest an OPTOISOLATOR chip.
Been looking for a PNP version, will have another look, its the inverting
thing which is the problem...
Chris
CWatters
No the tricky bit is getting a low impedence output when there is no power
on the circuit to turn on a regular transistor. Try a depletion mode FET.
exxos
Yeah low output impedence with no power is the fundimental problem, not
heard of a fet like that, just googled for them and doing a bit of reading
now :)
Cheers,
Chris
exxos
several pages latter I quote..
"A depletion-mode MOSFET conducts current without a gate bias. In an
n-channel device, a thin n-type region exists under the oxide in the absence
of an applied bias. It connects the source and drain allowing current flow.
In fact, a negative voltage is required to drive the electrons out of
(deplete) the region to increase channel resistance and reduce current
flow."
so basically its normally on though I found they actually have a on
resistance of 100ohms going by the ones ive found so far. All sounds good
until you read that it needs a negative to switch it, this reminds me of
thermal valves also, maybe if I fake the ground level by a volt or 2 then in
effect the gate voltage will be 2 volts under the source voltage... even so
the actual supply rail goes high so not sure how I can get negative switch
from a possitive rail.. oh the joy.....
Chris
CWatters
I'm a bit rusty but I think you are referring to an N-Type device. Perhaps
look at at P-Type instead.
CWatters
See also P-Type JFETs
exxos
will have a look for some p devices,
cheers,
chris
