SteelSeries X9 - converting to USB c port.
Siedlik
Nov 3, 2023
I got 2 pairs of SteelSeries X9 and the charging port Micro USB broke off. I decided to replace it with USB C, but something is not right.
When charging, the Amps do not go lower than 0.400A, even after a few hours.
On a working pair, the charging amps start from about 0.300A and goes to 0.0A till fully charged.
Also when the headphones are on, when I try to charge them they are turning off straight away.
Would there be some kind of short on both of them with USB C?
I was also thinking about installing a tiny board charger and connecting it straight to the battery.
Siedlik
Nov 3, 2023
Without getting too involved straight away, micro USB is different to USB C.
You can’t just swap Willy nilly!.
Martin
I have used a USB C port with 2 wires, how do you think I would solder them?
Martaine2005
May 12, 2015
5,317
USB-C can be connected either way, so only using two wires can potentially cause reverse polarity.
Get the correct connector for your headphones.
Martin
