Converting low resistance pot to high resistance ?
N
N Cook
Over the years I've often done the opposite by putting a resistor between
wiper and low end and another from wiper to high end.
just in case I've missed something over the years is there a way of say
converting a 20K pot to a 100K pot, with full range from bottom to top ?
Meat Plow
No.
How can you make a 100k pot when youve got a variable R that only
covers 20k. The answer is you cant. But there are 2.5 buts:
1. if its a ganged pot its poss to put the 2 tracks in series, doubling
R. But you cant then have a tapoff that moves anywhere along that track
length. However in many apps its ok to use a 2 terminal variable R, so
this will sometimes do.
2. You may be able to cut the track width down to increase R. Lot of
hassle though!
3. Some ccts can be tweaked so they run happily with a lower value pot.
But in these days of material overflow, its hard to think of any reason
to do any of the above now.
NT
hassle though!
NT
or lots of cuts across the track 2/3 of the way on alternate sides will
convert a straight track into a wiggly hence longer and higher R one.
All depends if youre in a shop or holed up in pow camp.
NT
Sam Goldwasser
Not with only passive components.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
C R Briggs
between
say
Add 4 off 20K fixed resistors in series, with a shorting switch across
each (or a rotary selector switch). You should get "steps" of 20K with
a 20K range adjustment in each step (i.e. 100K variable down to 80K; 80K
variable down to 60K: 60K variable down to 40K: 40K variable down to 20K
& 210K variable down to 0).
Regards,
C R Briggs.
Reply to address is munged. To reply, remove surplus spaces from:
btyguard-dontspam @ yahoo . co . uk
C R Briggs
with a 20K range adjustment in each step (i.e. 100K variable down to
80K; 80K variable down to 60K: 60K variable down to 40K: 40K variable
down to 20K & 210K variable down to 0).
Regards,
C R Briggs.
DOH!
Should of course be:
i.e. 100K variable down to 80K; 80K variable down to 60K: 60K variable
down to 40K: 40K variable down to 20K & 20K variable down to 0.
Regards,
C R Briggs.
that sounds like a challenge if ever I heard one :)
Take a 100k resistor, scrape the paint off one side. Cut a hole in the
track to fit it in, glue it there, and connect the leads to the ends of
the track. Paint over the remaining track. Now, if its all set up
right, the 100k R acts as the new track.
For more, google foxhole.
NT
Sam Goldwasser
Not quite what I had in mind. :)
K
Ken Weitzel
Hi...
OK, another way to do it, then.
Dis-assemble the control. Attach your meter across the outside
contacts. With a piece of fine sandpaper start sanding away at
the track. Stop when the meter says 100k. It may or may not
be linear, dependent on your sanding abilities.
Take care.
Ken
