Skybuck Flying
- Jan 1, 1970
- 0
I plan on buying the antec 1200 case which will house two nvidia gtx 7900
cards (with soundblaster sandwhiched between them) and maybe the scythe
zipang cooler on the amd x2 3800 processor which is on the asus a8n32-sli
motherboard.
Question about the cooling:
1. What is the best cpu cooler for the antec 1200 case (relating to airflow
I am worried about: airflow obstruction of big cpu coolers.
I am worried about: airflow disruption because of cooling fans.
I am worried about: electronics around cpu not being cooled.
I am worried about: top down coolers as well... maybe they just blow hot air
towards electronics ? though "they" say this is good... blowing cool air
towards electronics around cpu is good too.
I am worried about: little heatsinks with big fans... what if fan dies ?
would be nice if heatsink is big enough for passive cooling and airflow via
case... (zipang kinda sux without fan cooling it seems
However the antec 1200 case has: two rear case fans... one top case fan.
So I have a little dilemma:
Maybe it's better to have a cpu cooler which blows away hot air towards the
exit/exhausts ?
But maybe this would be bad for the electronics on the motherboard... they
might not be cooled enough.
I am especially worried about the motherboard. Two motherboards have already
died probably because of overheat.
So I am mostly looking for best motherboard cooling solution. !!!
So best question is:
2. What is the best motherboard cooling solution ?
I think this comes down too:
Which cpu cooler is best to cool the motherboard as well ?
Or are there maybe even special motherboard cooling solutions ?
I do have passive heatsinks on motherboard, maybe this was a bad choice.
However I do not know what caused the failures... maybe it's near the gpu
cards which can get quite hot it seems.
Some more questions:
3. Will the Scythe Zipang fit on the asus a8n32-sli motherboard ?
Reviews are good about the zipang... it's a top down cooler which means it
blows cool air towards the motherboard which is good for cooling the
electronics on it. But will it fit on the motherboard ? It's quite big.
Any mounting issue's ? For me it's probably no problem to take the
motherboard out of the case... I have to do that anyway... So mounting
outside case should be no problem (?)
4. In which direction do the xfx nvidia 7900 gtx fans blow air ?
Do they blow air towards their chips ? Which would be in the
case-up-direction ?
Or do they blow air downwards away from their chips ? Which would be in the
case-down-direction ?
I ask this because I will have to place the seasonic s12 power supply
up-side down on the bottom.
Therefore I wonder how the airflow will be effected ?
Will the power fan and the bottom gtx fan work against each other ?
Or will they work nicely in tendem... gtx expelling heat to power supply ?
Maybe this is not a problem... but maybe it is a problem ?
At least they should both be able to suck in air side-ways.
The antec 1200 is slightly bigger than my current case but not much so
that's ok.
This mostly covers the questions I have.
Bye,
Skybuck.
motherboard.
exit/exhausts ?
case-up-direction ?
that's ok.
Bye,
Skybuck.
