Coputer to Lab power supply conversion
Hey everybody. I am a hobbyist in the field of electronics with no
formal training. I have a pretty good understanding of components but
know basically nothing about systems as a whole. I got my hands on an
old computer supply and read about converting them for use as a lab
power supply. The directions said the poower supply needs to be loaded
to run, For their 450 watt power supply a 10 ohm 10 watt resistor was
used. My power supply is only a 90 watt, 10 ohms sounds like overkill.
I have a 250 ohm power resistor laying around. by my calculations this
will pull about 45 milliamps at 12 volts. Does this sound like enough
to load my 90 watt power supply? if not how many amps will it take?
thanks in advance!
Jamie
thanks in advance!
YOu need to try it..
I would say most likely it'll work.
Some people put a 12 incandescent lamp on the circuit so that it can
be used for both load and indication!
http://webpages.charter.net/jamie_5"
