correct wiring
Crafts4Me
Feb 10, 2022
175
hi
i am trying to repair an old discontinued electronic waterfall picture where a motor turns some rods and films with squiggly lines and its lit up and since the picture is a bit transparent it looks like water flowing
the motor died - a TYD50 synchornous 110v motor
i replaced the motor successfully ,however now one of the flurescent bulbs wont work
i bought a 100 v led strip with transformer as a replacement
1- there is no way to tell from this ancient chinese wiring which is + or -, the motor doesnt either describe. can it be i connected it incorrectly so the light doesnt work?
2- how do i know how to connect the led strip if i cant determine + or -
what can happen? can it blow up? not work? i want to only touch the wires for a second to see if it works and if yes make the connection if not try again
i am frightened
14,317
This one is going to work on AC (mains). There is no "+" or "-".
The primary side of this will be connected to mains AC, too. The secondary side, where the LEDs sit, should include the correct wiring and connectors. Usually these can be plugged in in one direction only, thus ensuring correct polarity.
Delta Prime
Jul 29, 2020
2,996
i am frightened
Boo! Did I scare you?
Can you take a picture of your waterfall picture without the water falling.
Crafts4Me
Feb 10, 2022
175
i will take a photo when it works ut i am scared to connect the LERD
i have the 110 plug one side with writing the other blank it doesnt say + or minus
this is connected to 1 set 2 withe wires 1 red the other 1 blue one red
how do i connect the Led to this
Delta Prime
Jul 29, 2020
2,996
Now follow my directions and take a photo of what you are doing cuz I cannot tell from your description if you need help. boo!!
Crafts4Me
Feb 10, 2022
175
i am the parent
noone to tell, maybe my spouse
my kids are married
my son taught me electricity basically baby stuff 12v only (not to say i didnt blow up a project, short out the lights and get a small burn because i forgot that 12v LED need a transformer)
he said i should wait for him to try when he comes to visit next. i wil not wait bec his visits arent often enough
here are photos of all the wires
tell me what to connect please
led has a brown and a blue i understand the brown is the live but where exactly do i connect it
Delta Prime
Jul 29, 2020
2,996
You say you have a hundred volt LED strip with transformer can you take a photo of that please or provide me the manufactures name and model number of that LED strip. Or a link to where you purchased it. Thank you. And don't you dare plug anything in the wall outlet. Or I'm going to tell your spouse. :p
Crafts4Me
Feb 10, 2022
175
the plug of it is already cut off and i have a blue and brown wire visible
14,317
The plug on which side? The 110 V side, I suppose?
In that case you connect the two wires to the 2 incoming wires from your 110 V AC mains. There is no + or - to confuse. Colors don't matter.
Crafts4Me
Feb 10, 2022
175
the LED strip plug is cut off
the remaining lamp and speaker and motor are all connected to the ac plug and working but no clude pos or neg
to what and how do i connect the LED
Delta Prime
Jul 29, 2020
2,996
You're running on 110 VAC
Now I have to go by the specifications and it says 220Volts AC it's not going to work. You Purchase the wrong unit.
Crafts4Me
Feb 10, 2022
175
i purchased the 110 version
it works on its own
i cut off the plug to reveal blue and brown wire
how do i connect it
kellys_eye
Jun 25, 2010
6,512
Follow the AC mains wire going in. It 'splits' and goes to two plastic 'turret' screw connectors, one with a red wire in it and one with a blue.
Connect your brown and blue to the red and blue respectively.
Crafts4Me
Feb 10, 2022
175
okso the brown is connected to the 2 white with the red and the blue is connected to the white and blue?
kellys_eye
Jun 25, 2010
6,512
Your reply is a bit convoluted but I think you've 'got it'. One (the brown) goes to the turret with the white/red in it and the pother (blue) goes to the one with white/blue in it. You should be able to unscrew the turret 'thing' and twist the bare wires together and then screw the turret back on over them.
Crafts4Me
Feb 10, 2022
175
it all turns on and works
motor turns and lights go on
does that mean i did the polarity correct or can it still be incorrect overheat and short?
kellys_eye
Jun 25, 2010
6,512
It's correct and will not overheat - unless there is a problem with the lights themselves but that seems unlikely.
Crafts4Me
Feb 10, 2022
175
i dont know
seems like eachpart i fix another one dies
maybe ists just too old and as soon as i power the new parts it overloads
now the sound machine part is broken
