Could someone please explain this?
Michael
I'm writing a program that interfaces with a device on the serial port and
in the documentation it says the folowing:
3.1.1. Header:Code.
The Header:Code combination is configured thus:
Header: 7 6 5 4 3 2 1 0
< Number of Dims> 1 F/A E/S
Where:
Number of Dims is a value between 0 and 22 identifying the number of dims to
be transmitted (22 is equivalent to 100%)
Bit 2 is always set to '1' to ensure that the interface is able to maintain
synchronization.
F/A defines whether the following byte is a function (1) or address (0).
E/S defines whether the following byte is an extended transmission (1) or a
standard transmission (0).
Could someone please explain what "Number of Dims is a value between 0 and
22 identifying the number of dims to be transmitted (22 is equivalent to
100%)" means?
A link to the documentation:
http://www.marmitek.com/en/software/PROTOCOL.DOC (Bottom of page 2)
Michael
V
vic
Michael said:
3.1.1. Header:Code.
Where:
synchronization.
100%)" means?
Michael
It means bits 7 through 4 form a 5-bit number to be interpreted as the
"dim" value. The value would be : (header & 0xF8) >> 3
There is probably some kind of linear interpolation where 22 means 100%
and 11 50%.
vic
Michael
and 11 50%.
vic
Thanks Vic
