Can someone please explain parts of this diagram
wedagedara
Feb 9, 2012
6
VISIT HERE
Please tell me what is:
R1:
R2:
R3:
C1:
C2:
And what are the four diodes used(in4xxx)
My electronic knowledge is not so good. I just need to repair my lamp.
Thanks a lot
14,317
The four diodes are a bridge rectifier. Input pins 1 and 3 are AC, output pins 2 and 4 are DC.
R1, C1 and R3 are current limiters. C1 operates on the AC side. The value 334 means 330nF. At 50 Hz this is equivalent to ~10kOhm. A capacitor is used instead of a resistor because it has lower power loss due to the phase shift between current and voltage.
R2 is for safety reasons. It discharges C1 when the lamp is turned off.
C2 is a smoothing capacitor. The DC voltage after the rectifier still has a large AC voltage superimposed which is reduced by C2.
wedagedara
Feb 9, 2012
6
No, i didn't meant to explain their works. I just asked what are the values of them(Eg: 10K, 33uF, etc). So it useful to buy them from a shop. The diagram is not clear to identify them,
So please tell me what are R1, R2, R3, C1 and C2.
CocaCola
Apr 7, 2012
3,635
Sure it is...
attachment.php
resistors are in ohms. C1 is 0.33uF and must be mains rated.
CocaCola
Apr 7, 2012
3,635
Generally recommended that C1 be 1.5-2.0 times or better than the mains rated in this application... This is to help compensate for transients in the mains supply...
When I say "mains rated" I mean that the capacitor is rated to be placed across the mains.
And my meaning was clearly not clear. So, for the benefit of wedegedara:
The lowest of these is Class X (there are also X1 and X2 with higher ratings).
See here.
