Counting 1-6 instead of 0-9 with a 74LS192 / 74LS47
Rikard Bosnjakovic
Greetings
My upcoming hobby project is an electronic die. The general idea behind it
is this:
A SPST-switch is connected to a capacitor and a 555 (astable version). The
capacitor is connected to ground through a resistor of some good value.
This is to make the pulse of random length to the 555, so the die won't
show the same value for each SPST-break.
The 555 sends its pulses to a BCD-counter (74LS192), which is connected to
a BCD-to-seven-decoder (74LS47) which in turn is connected to a common
anode 7-segment led.
I have constructed the circuit and it works fine, except for one thing;
the leds go from 0-9, but I want them to go from 1-6.
Before I used the 74LS47 and a segment led, I used a 74LS42 and ten LEDs
(just for the purpose of testing). When the counter reached "7", I
directed the current to the reset-pin on the 74LS192 and the counting got
started over.
What I'm looking for is some solution to do the same thing when I use the
LED-segment and the 74LS47.
Also, I have no real clue yet how to start on number 1 instead of 0.
Adding 1 to 0 would ofcourse do it, but my knowledge is still too limited
to see an immediate solution for this particular problem.
Hints, anyone?
Rikard Bosnjakovic
got started over.
A solution that just struck me was to connect a three-input AND-gate to
output a, b and c of the counter and the output of the AND to the
reset-pin. 7 is 111 binary, and when the outputs are high, it will reset.
This will limit the counting to 6 (right?), but I still have no clue of
how to start at 1 instead of 0. Perhaps make input-a of the counter to be
high at all times?
And no, I have no knowledge about PICs or anything like that, although I
know that using one would make this project easier.
Bob Monsen
The 74LS192 has a parallel load function. So, you hard-wire the parallel
load inputs to equal binary 1, and instead of doing a reset with 0111, you
use it to load the counter. Sadly, the load function is active low, so you
need a 3 input NAND gate for the load function.
I haven't tried this, so I don't know if there are strange glitches.
However, for your application, I suspect they'll happen so fast you won't
notice them.
petrus bitbyter
Rikard Bosnjakovic said:
Greetings
is this:
started over.
Hints, anyone?
Rikard,
You can use the PRESET input to make the counter start at 1. As the preset
is asynchronous, you have to preset when the counter reaches 7. A
quick-and-dirty way to achieve this is using a three input NAND. Inputs to
Qa, Qb and Qc. Output to the PRESET. You may need to stretch the pulse by an
RC combination. See below. Of course the A, B, C and D -inputs of the
counter have to be connected to Vcc, GND, GND and GND respectively.
__
Qa---| | ___
Qb---|& |o--|___|-+----PRESET
Qc---|__| 100 |
74LS10 ---
|1nF
GND---------------+------
created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
petrus bitbyter
John Fields
notice them.
The 192 has an asynchronous parallel load, so there _will_ be
glitches in the NAND's output which will load the 192 at unexpected
times. The solution is either to buffer the output of the NAND with
a "D" type flip-flop or to switch to a counter with a synchronous
parallel load, like a 161 or 163.
A serendipetous result of doing it that way is that the circuit's
POR will set the output of the counter to zero on power-up,
capturing the first count acuurately as '1', and thereafter will
roll over to '1' inxstead of '0'.
Also, he can use the AND he has now and get the inversion he needs
for the load from the flip-flop's Q\ output.
John Fields
H
Howard Delman
petrus said:
Rikard,
__
Qa---| | ___
Qc---|__| 100 |
74LS10 ---
|1nF
petrus bitbyter
Asynchronous presets, loads, and clears are a BAD idea. Inevitably,
they will glitch and cause erratic behavior. Do it right. Use a
counter with a synchronous preset, such as a '160 or '161. (Since you
don't count beyond 6, either binary or bcd will work.) Use a two input
nand to decode state 6 (Qb !& Qc), and connect its output to the
counter's preset input. Hardwire the four preset inputs to 0001b.
Connect the asynchronous reset to your other reset.
Howard Delman
Rich Grise
Greetings
is this:
Well, the counting/decoding question has been thoroughly answered - but
I'm wondering, how do you get "the pulse of random length to the 555"?
I've also thought about making an oscillator that starts fast, and
gradually slows down to about 1 Hz, then stops. But I don't know how
to do that yet, at least not without some effort on my part. ;-)
Rich
John Fields
Greetings
is this:
started over.
Hints, anyone?
Better way:
Let the 555 astable run fast and clock the counter, and use your
SPST switch to enable the counter. While it's pressed, let the
counter run, and when it's released, freeze the counter.
Or, while it's pressed, release the reset on the 555 and let it run,
and when it's released, hold the 555 in reset.
John Fields
petrus bitbyter
Howard Delman
Howard,
I agree. That's why I named it "quick and dirty". But the OP uses an LS192
and asked for a solution with it. You may bet the RC is not anly stretching
the pulse somewhat, it hopefully also kills unwanted gliches.
petrus bitbyter
John Fields
Better way:
Better yet, count down.
That way you can use the terminal count output to load the counter,
glitch-free, and get rid of the decode.
Like this:
(View with a fixed-pitch font like Courier)
Vcc Vcc--+---+
|S1 GND---+---|---|---+------+
O | | | | | |
+-----[1K]----+ O | +--+---+---+---+---+ |
| +-------+ | | | D3 D2 D1 D0 | |
+--|TH OUT|--+---|---------|>DOWN MR|--+
| |___ _| | | |
+-O|DIS R|O-----+ Vcc---|>UP LS192 |
| +-------+ | |__ ____|
[0.1µF] 7555 [10K] +--|PL TCDN|--+
| | | | Q3 Q2 Q1 Q0 | |
GND GND | +--+---+---+---+---+ |
| LS47 |
John Fields
Better way:
Like this:
Vcc Vcc--+---+
O | | | | | |
| |___ _| | | |
| | | | Q3 Q2 Q1 Q0 | |
| LS47 |
And, if you want to blank the LS47 while the "die is being rolled":
Vcc Vcc--+---+
O | | | | | |
+--|TH OUT|--+-----|------------|>DOWN MR|--+
| |___ _| | | |
+-O|DIS R|O--+----+ Vcc---|>UP LS192 |
| +-------+ | | |__ ____|
[0.1µF] 7555 | [10K] +--|PL TCDN|--+
| | | | | Q3 Q2 Q1 Q0 | |
GND | GND | +--+---+---+---+---+ |
| Vcc +-----|---|---|---|------+
| [10K] +--+---+---+---+--+
| | | 8 4 2 1 |
| | |__ ___ |
| +-----O|BI/RBO LS47 |
| C
+--[47k]--B NPN
GND
Doesn't this help produce a more random output? Wouldn't this be
preferred in this application?
John said:
No, since if the glitches occur (which is almost certain) they won't
occur randomly and there there will be states in the 1-to-6 sequence
which will be skipped by the load occurring at the improper place
because of the glitch.
I disagree. If you decode only the lower three bits, you are limited
to 0-7. You reset the counter instantaneously on x111, so it doen not
matter if it accidentally gets set to x111 since it will be forced to
an allowed state after detecting the overflow. Getting reset to x000
might be a problem, but this is unlikely if the inputs are hardwired to
asynchronously load an allowed value (presuambly x001). If I were
paranoid, I might force a reset on both x111 and x000.
I think you are overdesigning to adhere to some hygienic principles.
In this application, if all you want is a randomized output, I would
cheapen it by taking taking advantage of "problems" like contact
bounce, and you might even be able to eliminate the 555.
John Fields
Even though a '192 is a synchronous counter and the outputs are all
supposed to change simultaneously, if you look at the data sheet
you'll find that there is a spread in time in how long it takes the
outputs to change state once the clock goes high. That means that
there will be glitches in the output of the decoder (if the decoder
is fast enough), and for any single counter chip and decoder, the
glitches will be repeatable and will appear at the same place in the
count sequence, time after time, as the counter is going through its
routine. For a NAND decoding x111, all that's necessary is for all
three of its inputs to be high at the same time, as could happen
when x101 goes to x110 if the LSB hasn't yet gone to 0 when the bit
next to it goes to 1.
That means that if the broadside load is 0001, when the counter gets
to 0110 the NAND will see 0111, its output will go low and it will
cause the counter to do a broadside load of 0001 which will kill
the counter's output, 0110, in a matter of nanoseconds. That will
render it unviewable, making 0110, essentially, a disallowed state.
Kinda like a die with six sides, but one of which is unstable, so
you never really get to see it.
I like your idea of using contact bounce to advantage, and I think
that doing that in conjunction with the last circuit I posted, which
will allow the decoder to be eliminated, might be an ideal solution.
That is, as long as the switch can be guaranteed to be noisy and not
have the same noise signature, time after time.
But, another problem I see is that of release bounce.
That is, doing it your way, if the switch was pressed and held, the
display would show a number and, then, when the switch was released,
another number would show up.
Not quite like shooting craps, huh?
I sse your concern about the data race condition. In a onesies
project, I would just see if there is a poblem. If there were, or if I
were doing a more careful design, a well-placed capacitor or RC at the
output of the NAND could required the x111 state to last for a few
hundred ns to a few us before it reset the counters.
You could tie the blanking input on the 7447 to the clock input on the
74192, and connect those to ground thought a NO PB SPST. In a
non-critical application like this, I would even leave out the pullup
resistor. As long as you buy a cheap switch, I think you can count on
it to bounce (that was not intended as a pun, but it came out that way).
Rikard Bosnjakovic
It's true I use an LS192 for counting, but that doesn't mean I'm limited
to that IC. It only happens to be that that IC is the only counting-IC I
have at home. I can, ofcourse, buy other ones.
Rikard Bosnjakovic
The reason I'm using a 555 is because I want a slight delay after I push
the button. I.e. I don't want "push button => make number", I want "push
button, let numbers run for a second, and then stop".
If you have other ideas for implementing this using some sort of a random,
feel free to hint me.
