Counting 1-6 instead of 0-9 with a 74LS192 / 74LS47
John Fields
I am surprised that you did not actually build a circuit this simple.
How do you learn about "practical" issues like layout, parasitics.
contact bounce, etc?
John said:
Actually, I commend him for simulating it first since he found an
error of mine that way _without_ building it and then having to
rewire it to fix it. Pretty smart move, I'd say.
I would have said that you confirmed that his simulation replicated
your diagram accurately, and that you were the one who actually found
the error. I would have given him credit for finding the error if he
had said that he had a question based on reading the data sheet, and
then asked you why you did it one way when he would have interpreted
the data sheet differently.
Rikard Bosnjakovic
The reason for that is because due to moving, my breadboard and all my
electronic equipment are packed in boxes. At this stage, I haven't
actually built anything, I'm just harvesting ideas and possible brainstorming.
Sal Brisindi
Why don't you use vintage technology and make the dice with a 555 timer
connected to a 4017 decade counter, 6 mpsa42 transistors and a Nixie tube. Now
you can count from 1-6 real easy and connect output 7 to the reset pin.... BY
the way, I am partial to nixie tubes..
Regards,
Sal Brisindi
http://www.tuberadios.com/nixie/
Jasen Betts
I was about to suggest doing it all in transistors, and having a 7-dot output
like a real dice.
2 3 4
4 3 2
I had a working circuit that'd run off 2.4V
basically a 2 transistor astable for the clock source driving
4 cascaded bistables.
Bye.
Jasen
petrus bitbyter
output
like a real dice.
2 3 4
4 3 2
Bye.
Jasen
Jasen,
Old and oldfashioned but great fun. Although I have to admit I don't see how
to connect that bistables to achieve a fair 1:6 chance for every throw. Ever
had the idea to go and collect dice circuits. Guess I'd need a big, big
harddrive for it. FAIK the latest dice can be made by a small micro, the
PIC12F629 or a similar tiny AVR.
petrus bitbyter
Jasen Betts
Jasen,
petrus bitbyter
Bistable one was wired to change state with every clock pulse
it drove the dot "1" with its Q output and was wired with its
~Q output to the set input of of the second bistable, and a
high-pass filters to the set inputs of the other two bistables.
The second bistable drove the dots labeled "2" and "3" with with its
Q output and it's ~Q output was wired to the reset input of the third
bistable via a low pass filter.
the third bistable drove the dots "4" and "5" with its Q output and like
the second bistable it's ~Q output was wired to the reset input of tjh next
bistablee, the fourth.
the fourth bistable drove the dots with it's Q output
and also with its Q output drove the reset input of the second astable
but via a resistor so that it wouldn't reset while it's set input was high.
this was how it worked 2 6 4
5 7 3
start
bistable 1 set this lights dot 1
all the others reset, no other dota alight display shows "1"
clock pulse.
bistable one switches, dot 1 goes out,
bistable 2 gets set signal so dots "2" light,
bistable 3 and 4 also get brief set pulses but as their reset inputs are
activated via low pass filters from bistable 2 and 3 respectively the don't
change state (they may glitch a little but it doesn't show).
so the dots "2" and "3" are lit - the display reads "2"
clock pulse,
bistable one switches, dot 1 lights,
set input to bistable 2 goes low (no effect) negative pulses on the set
inputs of bistabl 3 and 4 (no effct)
so the so dots "1","2" and "3" are lit - the display reads "3"
clock pulse.
bistable 2 gets set signal (it's already set) no effect
bistable 3 gets the set pulse as bistable two is already set there's no
reset signal present so it changes state, dot's "4" and "5" light.
bistable 4 gets the set pulse but is reset via the low pass filter from
bistable 2 (so no change)
so the so dots 2,3,4,5 are lit - the display reads "4"
clock pulse.
so the so dots 1,2,3,4,5 are lit - the display reads "5"
clock pulse.
bistable 3 gets the set pulse (it's already set) no effect
bistable 4 gets the set pulse as bistable 3 is already set there's no
reset signal present so it changes state, dot's "6" and "7" light.
bistable 2 gets the weak reset signal but as there's a set signal present
doesn't reset
so the so dots 2,3,4,5,6,7 are lit - the display reads "4"
clock pulse.
bistable one switches, dot 1 lights, the set input to bistable 2 goes low
the reset input (from bistable 4s output) resets bistable 2 now that the
set input is low bistable 2 changes state. dots 2 and 3 go out, bistable
2's ~Q output goes high,
the high on bistable 2's ~Q output passes through the low pass filter and
resets bistable 3, bistable 3 changes state. dots 4 and 5 go out, bistable
3's ~Q output goes high,
the high on bistable 3's ~Q output passes through the low pass filter and
resets bistable 4, bistable 3 changes state. dots 6 and 7 go out, the
reset signal to bistable 2 turns off.
so dot 1 is lit, and the display reads "1" again.
this is the state I started with.
I'm not sure of the exact details of the conection to bistable 2's reset
input. there may have also been a primitive diode-resistor "and" gate
combining bistable 4's Q output and bistable 1's ~Q output instad of
the resistor I describe above...
Bye.
Jasen
