Kevin Weddle
- Feb 23, 2004
- 1,620
- Joined
- Feb 23, 2004
- Messages
- 1,620
I believe that a coupling capacitor is directly affected by DC. I am talking about low value capacitors that see the signal as discreet DC values because the signal rate of change is low. I can prove this theoretically. Whenever the signal goes DC, the other side of the capacitor will go to it's DC bias. It is often taken for granted, but when the signal stops changing, the signal on the other side of the capacitor jumps to it's DC bias and this is a distortion of the input.
Also, I have stated before that there exists a problem with using very small capacitors. The RC time constant is so short that capacitor completely charges with every value of the signal. It is desireable to have a capacitor charge in a few time constants so that you don't witness the charging curve of a capacitor. When the capacitor is sitting there at 3v, and then the signal goes 4v, you have a capacitor charging curve. Now if you do it in 3 time constants instead of 5 then the signal is better reproduced.
There is a linear protion to the capacitor charging curve. By linear we mean that we introduce a function between voltage and time that follows a straight line. So although the angle of the function can be anything, it is at least predictable. As the capacitor charges for every discrete value of the signal, it inserts a slightly different rate of change than the input because of the charging curve of the capacitor.
