O
orvillefpike
- Jan 1, 1970
- 0
The clamp on by its very nature can't measure DC, so you're all right there.
Set your Wavetek to measure AC volts and connect it to your DC power supply with
the supply set to put out maybe 5 volts (with the range of the Wavetek set
appropriately to measure 5 volts). If the Wavetek reads essentially zero, then
it's not a true RMS AC+DC meter, and you're good to go.
If the transformer core is substantially into saturation, the unloaded primary
current will be high, as you have noted in the MWT transformer. The coupling
coefficient will be reduced somewhat. The additional IR drop in the wire of the
primary will reduce the efficiency of the transformer (increased temperature
rise as a result) and will degrade its regulation. But, it will still perform
as a transformer.
Gapping the core of a transformer will cause performance degradations similar to
those caused by saturation. The no load excitation current will go up, causing
extra losses.
- Show quoted text -- Hide quoted text -
M. Resenbaum
have to take a few turns out of the primary (which I don't want to do)From what I know, to get the transformer away from saturation, I would
or lengthen the core (which would be complicated) or reinstall the
magnetic shunt, am I right? Is there other way to achieve that?
I often see air gaps in large inductor, my guess was that they did
that so they didn't have to make a large steel core. I thought I could
do the same in a transformer.
Thanks again
