Crate BV150H
N
N_Cook
What sort of quiescent mains draw current (240V land) for 6x good 6L6 and
remainder of the amp , if the bias has not been messed around with ?
Meat Plow
and remainder of the amp , if the bias has not been messed around with ?
Fuse is 3A SB for 230V. I'd expect less than 1 amp idle. Didn't you ask
about this amp back in 2009?
N
N_Cook
That was "lighthouse" neon 47K dropper for 110V used in uk on 240V. Same
with this one needing the mains switch changing , charred and part melted sw
cover this one but holding up at 47K.
This one been run too long with insufficient bias and run away red valves.
Phil Allison
"bored junkie"
Check plate current directly. Its not a great idea to ballpark bias by
mains current...
** Wrong - as always.
..... Phil
Phil Allison
"bored junkies are all losers "
mains current...
..... Phil
Phil Allison
mains current...
** Wrong advice - as always.
..... Phil
