creating my own wall charger 5v
Status
Not open for further replies.
amz mario
Oct 24, 2015
16
So I wish to make my own charger using own components and half cut off part of a usb charger. The one which plugs into a phone. A galaxy. So if I add a socket to this and my wire ..n plug it in. Will it blow my phone or be safe? This is the circuit I intend to create http://m.instructables.com/id/5v-Regulator/
A USB charger is already 5V.
What are you actually after?
amz mario
Oct 24, 2015
16
Create a wall charger for a phone to plug inti the wall without blowing it.
that link to the instructable seems superfluous then.
Assuming the charger is a usb charger then there is nothing technically preventing you from chopping off the plug and replacing it with a USB socket. Just write it up circuit.
if done correctly there should be no risk.
amz mario
Oct 24, 2015
16
I mean I wabt one end plugged in my phone n the other in the wall. So basically make my own wall charger. Which circuit do I need to create. Ans what do I need to buy. I have a cable which is cut and the only end I wish to use is the one whivh goes in the phone. The other end is wires. I cant jus tie that to a socket n plug it in . It'll blow. What do I need to create
Thank you
you need to buy a USB charger and the appropriate cable.
you can't build them for the price they sell for.
14,485
yup, what Steve said,
and going by your posts so far, you don't have the electronics experience to experiment with mains voltages in a safe way
for you own and the other's safety, get experience with battery powered projects before you start playing with mains power :)
cheers
Thread closed for everyone's safety
Status
