Creative CT1975-SAM pinout or equivalent?
N
N_Cook
No info found on these 11 pin audio output devices except
"Creative used these amplifiers in the previous generation speaker systems,
like FPS-1000 and FPS-1500."
Here used on one channel in a 2001 Cambridge soundworks desktop theater
DTT2200, other numbers on the chassis EAX CSW 4300
N
N_Cook
looks like failure in data-known ICs TDA7372 or M51132, not CT1975
For 2 known good CT1975 , DC V, no load
pins 1 to 11
0.8(ch2 in), *, 0,8,0.8(ch1 in),0(gnd),8,8(op1),16 (sup), 8(op2),12.3
* is 2 V on one used as 2 separate channels
and varies (no pcb connection to that pin) 0 to 0.6V floating presumably, on
one probably set in bridge configuration driving the sub-woofer.
Anyone have a more complete pinout/full data, JIC ?
N
N_Cook
pins 1 to 11
pin11 is standby
pin3 connected to ground
any guesses on the next 2
p7
in normal amp 100uF cap to ground
subwoofer amp 220nF to ground
p2 on the CT1975 where there is a connection to p2
100K to ground and also to the base of a TO92 via an r,
