John Tserkezis
- Jan 1, 1970
- 0
I have a Cree XLamp MC-E that suffered a catastrophic failure (open
circuit, and the clear reflector has come off the die).
I haven't been able to get a straight answer out of any googling or
datasheet perusing, so I'm asking here. The reliability spec sheet
absolutely abuses the leds before failure, from what I can guess, more
than I have here, so I'm at a a loss.
It lives in a bicycle light, I have the star led die bolted to an
aluminium block about 1cm thick, within a PVC pipe section, and a
further heatsink bolted to the other side of that.
All applicable surfaces were honed, (not polished, but smooth and
flat), and heatsink compound applied. The only surface I did not touch
was between the actual LED die, and the aluminium star surface it's
mounted on - that was left "factory standard".
My first test was in a still room (ambient was about 16C (60F) or so)
after about 15-20 minutes, the temperature probe (positioned near the
block) rose to about 65-70C (150F) before I shut it down. The heatsink
was quite warm to the touch at that point. Not _quite_ hot enough to
pull my hand away, but nearly there.
Since it's mostly sealed, I didn't have opportunity to measure lead
temperature, or anywhere near the actual die star for that matter.
On the road, it ran for a solid 2.5 hours or so absolutely perfectly,
with the heatsink temperature barely at "warm to the touch". (I didn't
have a temperature probe on it on the road).
The failure occurred the next day when I was demonstrating the light
to friends. It ran for several seconds before I moved the bike a bit,
where it failed. I had thought it was a wiring issue, till I measured
and then dismantled the assembly (it was O/C) to find bubbles in the
MC-E clear lens (mostly around the emitter output edges), and found the
lens came off quite easily with my finger.
Did the initial 'test' kill or stress it? Should I have a larger
heatsink? I am most certainly not the first person to use this led, so
what went wrong here?
Again, I didn't have access to the die temperature, and since it's
mounted on the star, how does one measure that anyway?
