Cross Reference for PCR 606J
stuee
May 7, 2004
183
Hi i have a light controller that has 2 of these in it and one went pop.
Only problem is i cant find a replacement.
If someone can help with some replacements ids i would appreciate it.
3 leg
Label  PCR 606J
Stuee
Alex Tsekenis
Nov 29, 2009
299
It is so annoying, these Chinese-made devices with non-standard part numbers.
Anyway, apparently the PCR606 is a thyristor in a T0-92 package with the following key specs:
V(DRM): : 400 v
V(RRM) : 400 v
IT(RMS) : 0.8 A
I(GT) :  V(AK)=7V
Max IGT=200 uA
V : 1.7 V
Try this:
http://uk.farnell.com/nxp/bt169d/thyristor-0-8a-400v-to-92/dp/1510734
Regards,
Alex
hotwaterwizard2
Jan 8, 2004
2,022
http://www.kcdec.com/download/2008918111259.pdf
http://parts.digikey.com/1/parts/989394-sensitive-gate-scr-0-8a-600v-low-ec103m2.html
http://www.teccor.com/data/en/Data_Sheets/E5SensitiveSCR.pdf
Hero999
Oct 28, 2007
2,433
Let me guess, it's a set of Christmas tree lights?
Any TO-92 SCR with an adequate voltage rating will probably do but be careful with the pin-out. It might be a good idea to check the pin-out for the one that works before getting a replacement.
I have some old Christmas tree lights I'm throwing way. I ripped open the controller and found four XL1225 SCRs which I'll desolder and test. The controller IC is marked SU168 which could be anything. It's a typical example of shoddy cheap Chinese construction and looks like a five year old put it together which is probably true.
Alex Tsekenis
Nov 29, 2009
299
I am surprised that they put an expensive (for Chinese product standards)  DIP package for the controller. Usually it's a COB.
rakeshkoku
Feb 19, 2010
24
