CRT Monitor Odd Behavior
Michael Kennedy
I've had this Viewsonic PF790 19" CRT monitor for quite a few years now and
it has been used daily since it was new without any issues. Recently I have
noticed that large white images will cause the horizontal size to shrink
about 1cm overall. I keep my desktop set to black so if I minimize a window
I see the picture expand or if I open a window I see the picture shrink. It
is possible that it has always done this, but I don't believe that it has.
Any thoughs on what might be going out?
Mike
Michael Kennedy
and it has been used daily since it was new without any issues. Recently I
have noticed that large white images will cause the horizontal size to
shrink about 1cm overall. I keep my desktop set to black so if I minimize
a window I see the picture expand or if I open a window I see the picture
shrink. It is possible that it has always done this, but I don't believe
that it has. Any thoughs on what might be going out?
Mike
I just set my monitor to 100hz, the setting I used to keep it at. With a
mostly black picture the desktop streches beyond the edges of the screen and
is dark and slightly purple. I guess I have some issue in the horizontal
deflection circuitry. I'm a novice at PC monitors so any suggestions would
be great.
Guest
be great.
No one needs a refresh rate that high. Set it to something
reasonable (e.g. 75 or 85Hz) and see if that helps.
Eeyore
Large white images require more current.
Clearly the supply voltage for that part of the circuitry is sagging under the
additional current demand. A PSU problem.
Graham
Sam Goldwasser
If it used to work and is within the specs of the monitor scan rate, then
that's not the issue.
Something is failing in the deflection or power supply, and the regulation
is suffering.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
AJ
Effect is called "Blooming" and is directly related to the power supply
circuits not able to supply the additional current required to display the
brighter raster, you will also notice a slight de-focus of the information
when the screen decreases in size.
Jim Yanik
then that's not the issue.
regulation is suffering.
my guess would be electrolytic caps,bad ESR.
You MUST use low-ESR,105degF caps for replacements.
Not a task I'd suggest for a neophyte,I suggest buying a new LCD monitor.
Jerry G.
With the ageing of the monitor, the power supply regulation and scan
circuit stability has decreased. The most common cause are electrolytic
capacitors going high in ESR. If all the capacitors in the monitor were
to be checked with an ESR meter, there is a possibility of finding many
of them out of specs. This may not be a feasible repair for a monitor as
old as the one that you have.
Jerry G.
and
have
window
It
has.
Mike
Michael Kennedy
Jim Yanik
jyanik
at
kua.net
Well it's not my first time working on a CRT, but I just don't have tons of
expirence. I've fixed minor things in TV's before, cold solder joints, etc.
I have an ESR meter so with a little time I should be able to find the
suspect caps.
Michael Kennedy
Well the interesting thing is that it appears to be doing the opposite. It
is clear when a large white image is on screen, but blooms when the image is
dark.
Mike
Michael Kennedy
As old? It is from 2001 I don't really think it is that old. I have
monitors way older than that.. I have an IBM VGA monitor from 1990 and a
Tandy CGA from about 1986 that works great still.
It would be nice to get a smaller monitor on my desk, but money is an issue
so I'll be re capping the monitor when I get time.
Interesting thing is that picture color, quality, brightness is all ok.
Guess it is probably in the deflection section.
msg
<snip>
Indeed, it 'floors' me each time I read this sort of time-perception in posts;
soon we will all have concepts of longevity appropriate for fruit-flies.
Anyway, one of our local universities recently put out hundreds of late-model
monitors in hallways for giveaway since they had converted to lcd to save
power campus-wide. Are you in an area with electronics recycling? Surely
back alleys also are good sources for discarded monitors. I find good
working ones nearly every day here in a smaller U.S. city, in all screen
sizes ;-).
Regards,
Michael
Sam Goldwasser
While I won't claim to have anywhere near the experience that you have,
what I have seen suggests that in many cases, it may infact be a single
bad cap with high ESR that is the problem, especially if the monitor or
TV had no obvious symptoms before.
James Sweet
Well it depends on the part of the circuit the parts are in. Nothing in a
monitor gets over 85C, but 105C caps will usually last longer. There's
little reason not to buy them, but you can use what you have on hand and it
will work in most cases.
Agreed on the first part, but the LCD monitor depends on whether he likes
them, I much prefer the image on a good CRT and know plenty of others like
me.
James Sweet
of expirence. I've fixed minor things in TV's before, cold solder joints,
etc. I have an ESR meter so with a little time I should be able to find
the suspect caps.
Look around the horizontal deflection and HV areas, really with an ESR meter
it's pretty easy to test almost all of the lytics in the monitor, hardest
part is getting to them, but the Viewsonics are not too bad to work on.
James Sweet
issue so I'll be re capping the monitor when I get time.
I replaced a pile of caps in a 14 year old 17" monitor a couple weeks ago,
the image looks better now than it has in years. It's old tech, but my mom
is still happy with it so I figured why replace it?
jakdedert
msg said:
<snip>
posts;
late-model
sizes ;-).
Absolutely agreed. Craigslist and Freecycle (google either one) list
free, working monitors every single day. Thrift stores will hardly
accept them...although they usually have a few for $25 or less. I put
out a working 17" on the curb the other day, just because I have so many
that I'm tripping over them. I finally had to toss it....
That said, I've got a 15" Sony composite sitting next to my desk as a
'repeater' for the home theater setup (hooked to a 'Video Sender' rf
receiver). It must be 20 years old, but works great.
jak
clifto
Which reminds me that time flies like an arrow, but fruit flies like a banana.
b
about 1cm overall.
start with the simplest: by changing the caps on the b+ line from the
power supply to the horizontal/line stage.. typically rated 160 volts
or more. don't bother measuring them, just replace. if no joy, then
work back into the primary of the power supply.
chances are this monitor has a few years of life left in it , so
don't give up and buy one of those 'orrid LCD things.
let us know how it goes.
-B.
Michael Kennedy
-B.
Well I thought it was thermally sensitive since it worked fine until the
monitor heated up... Now it appears to work fine for the time being. I'm
sure that I will have to fix it at some point, but right now it is not
showing any symptoms. I guess I'll have to wait for it to act up again.
Mike
