O
OBones
- Jan 1, 1970
- 0
I'm currently planning the conversion of an AT computer power supply
that I have lying around into a base supply for my hobbyist electronics
projects .
I know that there is a reason a lab supply costs that much, but for the
use I'm planning, a computer supply will be enough.
However, I would like to protect it against overload as I have no idea
if the supply in itself is fitted with such circuit.
I know I can use a fuse, or a PPTC but this type of circuit does not
give me any indication that it is about to shutdown the power.
I have in mind an old model train transformer that had a red light that
progressively lights up as one approaches overload up until it is fully
on and the supply to the system is shutdown
I would thus like to reproduce this kind of behavior but I must admit
that I'm a bit lost as to what starting point I could use.
What resources would you recommend?
Are there any base circuits that I can modify easily to add an indicator
light?
Thanks for your help
OBones
projects .
light?
OBones
