Petkovic
- Jan 1, 1970
- 0
Hi, I need to measure current in the range of 1mA to 10A.
The precision I need is 0.1% of the current that I'm measuring i.e for
10A current i need 10mA resolution for 1A I need 1mA resolution and so
forth. Potential across resistors are fed to an Opamp that has offset
and gain trimming networks.
The current is changing within the range limits and I need to measure
current continuously and send the value to computer.
I have built a prototype but I have some problems that I hope you can help.
Because the range is too broad to be measured accurately with only one
resistor, I have used these resistors:
0.1 Ohm -> 1A to 10A
1 Ohm -> 100mA to 1A
10 Ohm -> 1mA to 100mA
Now Problems that I have :
1- When I try to calibrate each resistor's gain an offset it causes a
gap with other resistors e.g. when current is increasing from 50mA to
200mA and I have to change current measurement resistor from 10 Ohm to 1
Ohm at point of change I read two different currents for 100mA i.e. 10
Ohm resistor reads it 100mA but 1 Ohm resistor reads it 115mA.
2- When current is high (>1A), current measurement resistor becomes hot
and after a while current that it reads change e.g. first it reads 2.16A
and after 10 minutes, it reads the same current 2.65A.
3- If I want to mass produce this, is it an easier way to calibrate
offset and gain of each resistor instead of manually change trim
networks of Opamp?
Thanks in Advance.
networks of Opamp?
Thanks in Advance.
