This could be use din parallel to the LED. If the voltage rises due to the removal of the LED or battery, the crowbar will short circuit the ring.
Only problem: how to turn off the crowbar after a new LED or battery has been inserted?
Harald
Too bad the current loop isn't pulsating DC. The SCR would reset itself, but then it wouldn't be a constant current loop. More like a max (peak) current loop.
If this is an emergency lighting system then a crowbar across the loop for other than over voltage from power supply failure would seem antithetical to an emergency lighting system. It would mean that if the user is removing - replacing a LED element he / she will be in the dark when the LED is removed. I would think that a system like this should have shunted sockets that close when the LED's removed and open when they're inserted. I'm not referring to a mechanical system either. I'm thinking of active sockets that know if a LED failed open too!
Chris
