current source transformation
bhuvanesh
Aug 29, 2013
201
i heard some lectures there they say that current in series with thevinen resistor.but it actually in parallel.Thank you in advance
Arouse1973
Adam
Dec 18, 2013
5,178
Any circuit containing just resistances can be converted into an equivalent Thevenin resistance. Don't know what you mean in parallel. In your posts you need to give more details. We can't read minds.
bhuvanesh
Aug 29, 2013
201
9bw444ahf
see the img.now say does the thevenin current is in parallel or series with resistor.actually if you see the subtitle.u can realize they says that current is parallel
14,487
neither image is showing for me
can you post the image on this site
The equivalence part of that is saying that a current source in parallel with a resistance is equivalent to a voltage source in series with a resistance.
For analysis purposes, any circuit that is comprised of voltage and current sources and resistors can be simplified to it's Thevennin equivalent. The same is true of a Norton equivalent.
bhuvanesh
Aug 29, 2013
201
i want to know why we are converting voltage source to current source.whats is the need to that(does converting is only for simplification purpose)
Electrobrains
Jan 2, 2012
259
It can be very practical.
For instance if you are dimensioning a circuit with components that are specified for a fixed current (eg. LEDs with a certain luminance at a certain current), but in the end you want to use a normal, cheap (voltage regulated) power supply.
