Cut heatsink tab off 7805
kickit2
Nov 20, 2011
14
Hey everyone.
I am putting together a circuit which draws only about 30ma from a 7805 (14v input). I'm trying to get everything as small as possible (without going smd) and I want the 7850 to lay flat. Issue is the heatsink tab turns this into a large footprint.
I'm am assuming that at 30ma the 7805 should do just find with its tab cut off. Can anyone confirm this?
It is not even getting warm with it on.
Kickit2
Raven Luni
Oct 15, 2011
798
At 14v there will be a bit of heat even with 30 mA draw. It is better to keep the tab and use the copper on the bottom of the board as a heatsink.
You can get a 78L05 in T092 if you want to save space.
GonzoEngineer
Dec 2, 2011
321
Just be careful how you cut it.......you can easily distor tit and fracture the die inside.
Don't ask me how I know!
Resqueline
Jul 31, 2009
2,848
I'm with Bob, with a mere 0.3W of dissipation a 78L05 is the way to go to save space.
OLIVE2222
Oct 2, 2011
690
Yes the TO92 package can handle the 0.3W, but adding a zener diode at the regulator input can give a bit more headroom (without being too bulky).
Olivier
